On Wed, 29 Apr 2009, Mats Rynge wrote: > The work directory will depend on what VO you are a member of. If you are > using your Engagement certificate, the second config should work. zhao's credential is in osgedu, I think, in which case he should use use the --vo=osgedu parameter to swift-osg-ress-site-catalog --
