[Swift-devel] feature request
    Mats Rynge
    rynge at renci.org
    Wed Apr 29 11:12:14 CDT 2009
Zhao Zhang wrote:
> Hi, again.
> Now I have two sites.xml for renci-engagement. The first one is working,
> while the second is not. The second sites.xml is generated by the script.
> Since the only difference between the first and the second is the
> <workdirectory> value, I am assuming the error is caused by the
> <workdirectory>.
> If this is true, how could I find all valid <workdirectory> for all
> sites on OSG?
The work directory will depend on what VO you are a member of. If you
are using your Engagement certificate, the second config should work.
Also note that using $HOME (like in the first example) is not a good
idea. Most sites on OSG, RENCI-Engagement included, have quotas for
$HOME. So, a workflow using more than 5GB of disk with the first config
will fail.
> First:
> <config>
>   <pool handle="renci-engage">
>      <gridftp  url="gsiftp://belhaven-1.renci.org/" />
>      <execution provider="condor" />
>      <workdirectory >/nfs/home/osgedu/benc</workdirectory>
>      <profile namespace="globus" key="jobType">grid</profile>
>      <profile namespace="globus" key="gridResource">gt2
> belhaven-1.renci.org/jobmanager-fork</profile>
>   </pool>
> </config>
> Second:
> <config>
>  <!-- RENCI-Engagement -->
>  <pool handle="RENCI-Engagement" >
>    <workdirectory
>  >/nfs/osg-data/engage/tmp/RENCI-Engagement</workdirectory>
>  </pool>
> </config>
> The error message is:
> [zzhang at tp-grid1 sites]$ ./run-site condor-g/RENCI-Engagement.xml
> testing site configuration: condor-g/RENCI-Engagement.xml
> Removing files from previous runs
> Running test 061-cattwo at Wed Apr 29 10:21:31 CDT 2009
> Swift 0.9rc2 swift-r2860 cog-r2388
> RunID: 20090429-1021-8ayf7v75
> Progress:
> Execution failed:
>        Could not find any valid host for task "Task(type=UNKNOWN,
> identity=urn:cog-1241018496704)" with constraints
> {filenames=[Ljava.lang.String;@7f38f3d1, trfqn=cat,
> filecache=org.griphyn.vdl.karajan.lib.cache.CacheMapAdapter at 740f5f97,
> tr=cat}
> SWIFT RETURN CODE NON-ZERO - test 061-cattwo
> Ben Clifford wrote:
>> On Wed, 29 Apr 2009, Zhao Zhang wrote:
>>> I modified the existing swift-osg-ress-site-catalog, and generate a
>>> sample
>>> sites.xml at CI network
>>> /home/zzhang/swift_coaster/cog/modules/swift/tests/sites/condor-g/sample-sites.xml
>>> Could you help me check if there is any known error in there? thanks.
>> I looked briefly and it seems ok
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Mats Rynge
Renaissance Computing Institute <http://www.renci.org>
