[Swift-devel] feature request
    Zhao Zhang
    zhaozhang at uchicago.edu
    Tue Apr 28 16:52:39 CDT 2009
Hi, Again
So here is the OSG site list of the VO "OSG", I am double checking that
I need to test all of those sites, right?
http://vors.grid.iu.edu/cgi-bin/index.cgi?VO=24&grid=1®ion=0&res=0&dtype=0
zhao
Zhao Zhang wrote:
> Thanks, Ben
> It worked, but there is an exception.
> zhao
> [zzhang at tp-grid1 sites]$ ./run-site condor-g/renci-condor.xml
> testing site configuration: condor-g/renci-condor.xml
> Removing files from previous runs
> Running test 061-cattwo at Tue Apr 28 16:04:38 CDT 2009
> Swift 0.9rc2 swift-r2860 cog-r2388
> RunID: 20090428-1604-cge2klv7
> Progress:  uninitialized:1
> Progress:  Stage in:1
> Progress:  Submitting:1
> Progress:  Active:1
> Progress:  Active:1
> Progress:  Stage out:1
> Final status:  Finished successfully:1
> The following warnings have occurred:
> 1. Cleanup on renci-engage failed
> Caused by:
>        Cannot submit job: Could not submit job (condor_submit reported
> an exit code of 1). no error output
> expecting 061-cattwo.out.expected
> checking 061-cattwo.out.expected
> Skipping exception test due to test configuration
> Test passed at Tue Apr 28 16:05:25 CDT 2009
> Ben Clifford wrote:
>> The version of condor that is on communicado probably won't work. i
>> have only seen this work with condor 7.0.x.
>> I think the version on teraport's tp-osg node should work:
>> ssh tp-osg.ci.uchicago.edu
>> $ source /opt/osg/setup.sh $ condor_version
>> $CondorVersion: 7.0.5 Sep 20 2008 BuildID: 105846 $
>> $CondorPlatform: X86_64-LINUX_RHEL5 $
>> On Tue, 28 Apr 2009, Zhao Zhang wrote:
>>> Hi, Ben
>>> Here is my sites.xml
>>> [zzhang at communicado sites]$ cat condor-g/renci-condor.xml
>>> <config>
>>>   <pool handle="renci-engage">
>>>      <gridftp  url="gsiftp://belhaven-1.renci.org/" />
>>>      <execution provider="condor" />
>>>      <workdirectory >/nfs/home/osgedu/benc</workdirectory>
>>>      <profile namespace="globus" key="jobType">grid</profile>
>>>      <profile namespace="globus" key="gridResource">gt2
>>> belhaven-1.renci.org/jobmanager-fork</profile>
>>>   </pool>
>>> </config>
>>> And, I started run-site to test this,
>>> [zzhang at communicado sites]$ ./run-site condor-g/renci-condor.xml
>>> Running test 061-cattwo at Tue Apr 28 15:49:03 CDT 2009
>>> RunID: 20090428-1549-rken3vo4
>>> Progress:
>>> Failed to transfer wrapper log from
>>> 061-cattwo-20090428-1549-rken3vo4/info/y
>>> on renci-engage
>>> 061-cattwo-20090428-1549-rken3vo4/info/0
>>> on renci-engage
>>> 061-cattwo-20090428-1549-rken3vo4/info/2
>>> on renci-engage
>>> Progress:  Failed:1
>>> Execution failed:
>>>        Exception in cat:
>>> Arguments: [061-cattwo.1.in, 061-cattwo.2.in]
>>> Host: renci-engage
>>> Directory: 061-cattwo-20090428-1549-rken3vo4/jobs/2/cat-26xkb2aj
>>> stderr.txt:
>>> stdout.txt:
>>> Caused by:
>>> reported an exit
>>> SWIFT RETURN CODE NON-ZERO - test 061-cattwo
>>> Any ideas on the failures? Do you need more information?
>>> zhao
>>>>> Is this the following a correct condor-G sites.xml ?
>>>> No, that will try to use gram4.
>>>> Have a look at this message for an example that I have successfully
>>>> used:
>>>> http://mail.ci.uchicago.edu/pipermail/swift-devel/2009-April/005115.html
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
