[Swift-devel] feature request
    Ben Clifford
    benc at hawaga.org.uk
    Tue Apr 28 15:54:00 CDT 2009
The version of condor that is on communicado probably won't work. i have
only seen this work with condor 7.0.x.
I think the version on teraport's tp-osg node should work:
ssh tp-osg.ci.uchicago.edu
$ source /opt/osg/setup.sh
$ condor_version
$CondorVersion: 7.0.5 Sep 20 2008 BuildID: 105846 $
$CondorPlatform: X86_64-LINUX_RHEL5 $
On Tue, 28 Apr 2009, Zhao Zhang wrote:
> Hi, Ben
> Here is my sites.xml
> [zzhang at communicado sites]$ cat condor-g/renci-condor.xml
> <config>
>   <pool handle="renci-engage">
>      <gridftp  url="gsiftp://belhaven-1.renci.org/" />
>      <execution provider="condor" />
>      <workdirectory >/nfs/home/osgedu/benc</workdirectory>
>      <profile namespace="globus" key="jobType">grid</profile>
>      <profile namespace="globus" key="gridResource">gt2
> belhaven-1.renci.org/jobmanager-fork</profile>
>   </pool>
> </config>
> And, I started run-site to test this,
> [zzhang at communicado sites]$ ./run-site condor-g/renci-condor.xml
> testing site configuration: condor-g/renci-condor.xml
> Removing files from previous runs
> Running test 061-cattwo at Tue Apr 28 15:49:03 CDT 2009
> Swift 0.9rc2 swift-r2860 cog-r2388
> RunID: 20090428-1549-rken3vo4
> Progress:
> Progress:  Stage in:1
> Progress:  Submitting:1
> Failed to transfer wrapper log from 061-cattwo-20090428-1549-rken3vo4/info/y
> on renci-engage
> Failed to transfer wrapper log from 061-cattwo-20090428-1549-rken3vo4/info/0
> on renci-engage
> Failed to transfer wrapper log from 061-cattwo-20090428-1549-rken3vo4/info/2
> on renci-engage
> Progress:  Failed:1
> Execution failed:
>        Exception in cat:
> Arguments: [061-cattwo.1.in, 061-cattwo.2.in]
> Host: renci-engage
> Directory: 061-cattwo-20090428-1549-rken3vo4/jobs/2/cat-26xkb2aj
> stderr.txt:
> stdout.txt:
> Caused by:
>        Cannot submit job: Could not submit job (condor_submit reported an exit
> code of 1). no error output
> SWIFT RETURN CODE NON-ZERO - test 061-cattwo
> Any ideas on the failures? Do you need more information?
> zhao
> > > Is this the following a correct condor-G sites.xml ?
> > No, that will try to use gram4.
> > Have a look at this message for an example that I have successfully used:
> > http://mail.ci.uchicago.edu/pipermail/swift-devel/2009-April/005115.html
