[Swift-devel] feature request
    Zhao Zhang
    zhaozhang at uchicago.edu
    Tue Apr 28 15:51:03 CDT 2009
Hi, Ben
Here is my sites.xml
[zzhang at communicado sites]$ cat condor-g/renci-condor.xml
<config>
   <pool handle="renci-engage">
      <gridftp  url="gsiftp://belhaven-1.renci.org/" />
      <execution provider="condor" />
      <workdirectory >/nfs/home/osgedu/benc</workdirectory>
      <profile namespace="globus" key="jobType">grid</profile>
      <profile namespace="globus" key="gridResource">gt2
belhaven-1.renci.org/jobmanager-fork</profile>
   </pool>
</config>
And, I started run-site to test this,
[zzhang at communicado sites]$ ./run-site condor-g/renci-condor.xml
testing site configuration: condor-g/renci-condor.xml
Removing files from previous runs
Running test 061-cattwo at Tue Apr 28 15:49:03 CDT 2009
Swift 0.9rc2 swift-r2860 cog-r2388
RunID: 20090428-1549-rken3vo4
Progress:
Progress:  Stage in:1
Progress:  Submitting:1
Failed to transfer wrapper log from
061-cattwo-20090428-1549-rken3vo4/info/y on renci-engage
061-cattwo-20090428-1549-rken3vo4/info/0 on renci-engage
061-cattwo-20090428-1549-rken3vo4/info/2 on renci-engage
Progress:  Failed:1
Execution failed:
        Exception in cat:
Arguments: [061-cattwo.1.in, 061-cattwo.2.in]
Host: renci-engage
Directory: 061-cattwo-20090428-1549-rken3vo4/jobs/2/cat-26xkb2aj
stderr.txt:
stdout.txt:
Caused by:
        Cannot submit job: Could not submit job (condor_submit reported
an exit code of 1). no error output
SWIFT RETURN CODE NON-ZERO - test 061-cattwo
Any ideas on the failures? Do you need more information?
zhao
Ben Clifford wrote:
> On Tue, 28 Apr 2009, Zhao Zhang wrote:
>> Is this the following a correct condor-G sites.xml ?
> No, that will try to use gram4.
> Have a look at this message for an example that I have successfully used:
> http://mail.ci.uchicago.edu/pipermail/swift-devel/2009-April/005115.html
