[Swift-devel] feature request
    Zhao Zhang
    zhaozhang at uchicago.edu
    Tue Apr 28 16:13:21 CDT 2009
Thanks, Ben
It worked, but there is an exception.
zhao
[zzhang at tp-grid1 sites]$ ./run-site condor-g/renci-condor.xml
testing site configuration: condor-g/renci-condor.xml
Removing files from previous runs
Running test 061-cattwo at Tue Apr 28 16:04:38 CDT 2009
Swift 0.9rc2 swift-r2860 cog-r2388
RunID: 20090428-1604-cge2klv7
Progress:  uninitialized:1
Progress:  Stage in:1
Progress:  Submitting:1
Progress:  Active:1
Progress:  Active:1
Progress:  Stage out:1
Final status:  Finished successfully:1
The following warnings have occurred:
1. Cleanup on renci-engage failed
Caused by:
        Cannot submit job: Could not submit job (condor_submit reported
an exit code of 1). no error output
expecting 061-cattwo.out.expected
checking 061-cattwo.out.expected
Skipping exception test due to test configuration
Test passed at Tue Apr 28 16:05:25 CDT 2009
Ben Clifford wrote:
> The version of condor that is on communicado probably won't work. i have
> only seen this work with condor 7.0.x.
> I think the version on teraport's tp-osg node should work:
> ssh tp-osg.ci.uchicago.edu
> $ source /opt/osg/setup.sh
> $ condor_version
> $CondorVersion: 7.0.5 Sep 20 2008 BuildID: 105846 $
> $CondorPlatform: X86_64-LINUX_RHEL5 $
> On Tue, 28 Apr 2009, Zhao Zhang wrote:
>> Hi, Ben
>> Here is my sites.xml
>> [zzhang at communicado sites]$ cat condor-g/renci-condor.xml
>> <config>
>>   <pool handle="renci-engage">
>>      <gridftp  url="gsiftp://belhaven-1.renci.org/" />
>>      <execution provider="condor" />
>>      <workdirectory >/nfs/home/osgedu/benc</workdirectory>
>>      <profile namespace="globus" key="jobType">grid</profile>
>>      <profile namespace="globus" key="gridResource">gt2
>> belhaven-1.renci.org/jobmanager-fork</profile>
>>   </pool>
>> </config>
>> And, I started run-site to test this,
>> [zzhang at communicado sites]$ ./run-site condor-g/renci-condor.xml
>> Running test 061-cattwo at Tue Apr 28 15:49:03 CDT 2009
>> RunID: 20090428-1549-rken3vo4
>> Progress:
>> Failed to transfer wrapper log from 061-cattwo-20090428-1549-rken3vo4/info/y
>> on renci-engage
>> Failed to transfer wrapper log from 061-cattwo-20090428-1549-rken3vo4/info/0
>> on renci-engage
>> Failed to transfer wrapper log from 061-cattwo-20090428-1549-rken3vo4/info/2
>> on renci-engage
>> Progress:  Failed:1
>> Execution failed:
>>        Exception in cat:
>> Arguments: [061-cattwo.1.in, 061-cattwo.2.in]
>> Host: renci-engage
>> Directory: 061-cattwo-20090428-1549-rken3vo4/jobs/2/cat-26xkb2aj
>> stderr.txt:
>> stdout.txt:
>> Caused by:
>>        Cannot submit job: Could not submit job (condor_submit reported an exit
>> SWIFT RETURN CODE NON-ZERO - test 061-cattwo
>> Any ideas on the failures? Do you need more information?
>> zhao
>>>> Is this the following a correct condor-G sites.xml ?
>>> No, that will try to use gram4.
>>> Have a look at this message for an example that I have successfully used:
>>> http://mail.ci.uchicago.edu/pipermail/swift-devel/2009-April/005115.html
