[Swift-devel] feature request
    Michael Wilde
    wilde at mcs.anl.gov
    Thu Apr 23 10:33:51 CDT 2009
My inderstanding is that Gwynn is the new gatekeeper replacing fletch
(as Ben says) so Fletch should be removed from the tests.
The tests should be annotated to call this the "HNL Condor Pool".
see also: http://www.ci.uchicago.edu/wiki/bin/view/CNARI/ResourceStructure
- Mike
On 4/23/09 10:20 AM, Zhao Zhang wrote:
> Yes, here it is:
> These sites failed: coaster/fletch-coaster-gram2-gram2-condor.xml
> coaster/fletch-coaster-gram2-gram2-fork.xml
> coaster/teraport-gt2-gt2-pbs.xml coaster/tgncsa-hg-coaster-pbs-gram2.xml
> coaster/tgncsa-hg-coaster-pbs-gram4.xml
> These sites worked: coaster/coaster-local.xml
> coaster/renci-engage-coaster.xml
> zhao
> Ben Clifford wrote:
>> On Thu, 23 Apr 2009, Zhao Zhang wrote:
>>> Error 1: This is related to CI network setting,
>>> /etc/grid-security/hostcert.pem. Could anyone help on this? Who should I
>>> contact?
>> fletch is broken. But try changing those sites files to use
>> gwynn.bsd.uchicago.edu instead.
>>> Error 2: My certificate is not enabled on teraport, As Mike and I
>>> talked last
>>> night, "certificate revocation list" on CI network is misconfigured.
>> This looks more like a permissions problem - the directory being used
>> in the sites.xml file for that test does not exist and you do not have
>> permission to create it.
>> In r2874 I have changes tests/sites/coaster/teraport-gt2-gt2-pbs.xml
>> to use a different path that should work for you now.
>>> Error 3 & Error 4: I am not active on tgncsa site. Mike said he
>>> needed to add
>>> me to another group.
>> yes.
>> Do you have the list from the end of your test run about which sites
>> worked and which did not?
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
