[Swift-devel] feature request
    Zhao Zhang
    zhaozhang at uchicago.edu
    Thu Apr 23 10:20:41 CDT 2009
Yes, here it is:
These sites failed: coaster/fletch-coaster-gram2-gram2-condor.xml
coaster/fletch-coaster-gram2-gram2-fork.xml
coaster/teraport-gt2-gt2-pbs.xml coaster/tgncsa-hg-coaster-pbs-gram2.xml
coaster/tgncsa-hg-coaster-pbs-gram4.xml
These sites worked: coaster/coaster-local.xml
coaster/renci-engage-coaster.xml
zhao
Ben Clifford wrote:
> On Thu, 23 Apr 2009, Zhao Zhang wrote:
>> Error 1: This is related to CI network setting,
>> /etc/grid-security/hostcert.pem. Could anyone help on this? Who should I
>> contact?
> fletch is broken. But try changing those sites files to use
> gwynn.bsd.uchicago.edu instead.
>> Error 2: My certificate is not enabled on teraport, As Mike and I talked last
>> night, "certificate revocation list" on CI network is misconfigured.
> This looks more like a permissions problem - the directory being used in
> the sites.xml file for that test does not exist and you do not have
> permission to create it.
> In r2874 I have changes tests/sites/coaster/teraport-gt2-gt2-pbs.xml to
> use a different path that should work for you now.
>> Error 3 & Error 4: I am not active on tgncsa site. Mike said he needed to add
>> me to another group.
> yes.
> Do you have the list from the end of your test run about which sites
> worked and which did not?
