[Swift-devel] feature request
    Zhao Zhang
    zhaozhang at uchicago.edu
    Thu Apr 23 11:18:18 CDT 2009
Hi, Ben
Ben Clifford wrote:
> On Thu, 23 Apr 2009, Zhao Zhang wrote:
>> Error 1: This is related to CI network setting,
>> /etc/grid-security/hostcert.pem. Could anyone help on this? Who should I
>> contact?
> fletch is broken. But try changing those sites files to use
> gwynn.bsd.uchicago.edu instead.
>> Error 2: My certificate is not enabled on teraport, As Mike and I talked last
>> night, "certificate revocation list" on CI network is misconfigured.
> This looks more like a permissions problem - the directory being used in
> the sites.xml file for that test does not exist and you do not have
> permission to create it.
> In r2874 I have changes tests/sites/coaster/teraport-gt2-gt2-pbs.xml to
> use a different path that should work for you now.
I tried this out, it failed, then I increased the wall-time to 15
minutes in the coaster/teraport-gt2-gt2-pbs.xml  file.
And I am waiting now.
zhao
[zzhang at communicado sites]$ ./run-site coaster/teraport-gt2-gt2-pbs.xml
testing site configuration: coaster/teraport-gt2-gt2-pbs.xml
Removing files from previous runs
Running test 061-cattwo at Thu Apr 23 11:12:09 CDT 2009
Swift 0.9rc2 swift-r2860 cog-r2388
RunID: 20090423-1112-6jqlxfcf
Progress:
Progress:  Stage in:1
Progress:  Submitted:1
Failed to transfer wrapper log from
061-cattwo-20090423-1112-6jqlxfcf/info/q on teraport
061-cattwo-20090423-1112-6jqlxfcf/info/s on teraport
061-cattwo-20090423-1112-6jqlxfcf/info/u on teraport
Progress:  Failed:1
Execution failed:
        Exception in cat:
Arguments: [061-cattwo.1.in, 061-cattwo.2.in]
Host: teraport
Directory: 061-cattwo-20090423-1112-6jqlxfcf/jobs/u/cat-umlmrs9j
stderr.txt:
stdout.txt:
Caused by:
        Job cannot be run with the given max walltime worker constraint
(task: 600, maxwalltime: 300s)
Cleaning up...
Shutting down service at https://128.135.125.118:58204
Got channel MetaChannel: 1297642 -> GSSSChannel-null(1)
- Done
SWIFT RETURN CODE NON-ZERO - test 061-cattwo
>> Error 3 & Error 4: I am not active on tgncsa site. Mike said he needed to add
>> me to another group.
> yes.
> Do you have the list from the end of your test run about which sites
> worked and which did not?
