[Swift-devel] feature request
    Ben Clifford
    benc at hawaga.org.uk
    Thu Apr 23 09:35:38 CDT 2009
On Thu, 23 Apr 2009, Zhao Zhang wrote:
> Error 1: This is related to CI network setting,
> /etc/grid-security/hostcert.pem. Could anyone help on this? Who should I
> contact?
fletch is broken. But try changing those sites files to use
gwynn.bsd.uchicago.edu instead.
> Error 2: My certificate is not enabled on teraport, As Mike and I talked last
> night, "certificate revocation list" on CI network is misconfigured.
This looks more like a permissions problem - the directory being used in
the sites.xml file for that test does not exist and you do not have
permission to create it.
In r2874 I have changes tests/sites/coaster/teraport-gt2-gt2-pbs.xml to
use a different path that should work for you now.
> Error 3 & Error 4: I am not active on tgncsa site. Mike said he needed to add
> me to another group.
yes.
Do you have the list from the end of your test run about which sites
worked and which did not?
