[Swift-devel] feature request
    Zhao Zhang
    zhaozhang at uchicago.edu
    Thu Apr 23 09:21:59 CDT 2009
Several Error Message from coaster test:
Here is my guess, correct me if I am wrong.
Error 1: This is related to CI network setting,
/etc/grid-security/hostcert.pem. Could anyone help on this? Who should I
contact?
Error 2: My certificate is not enabled on teraport, As Mike and I talked
last night, "certificate revocation list" on CI network is misconfigured.
Error 3 & Error 4: I am not active on tgncsa site. Mike said he needed
to add me to another group.
zhao
Error 1:
testing site configuration: coaster/fletch-coaster-gram2-gram2-condor.xml
Removing files from previous runs
Running test 061-cattwo at Thu Apr 23 07:55:35 CDT 2009
Swift 0.9rc2 swift-r2860 cog-r2388
RunID: 20090423-0755-2kxbne86
Progress:
Progress:  Initializing site shared directory:1
Execution failed:
        Could not initialize shared directory on teraport
Caused by:
        org.globus.cog.abstraction.impl.file.FileResourceException:
Error communicating with the GridFTP server
Caused by:
        Server refused performing the request. Custom message: Server
refused GSSAPI authentication. (error code 1) [Nested exception
message:  Custom message: Unexpected reply: 530-globus_xio: Server side
credential failure
530-globus_gsi_gssapi: Error with GSI credential
530-globus_gsi_gssapi: Error with gss credential handle
*530-globus_credential: Error with credential: The host credential:
/etc/grid-security/hostcert.pem*
530-     with subject:
/DC=org/DC=doegrids/OU=Services/CN=fletch.bsd.uchicago.edu
530-     has expired 77452 minutes ago.
530-
530 End.]
Error 2:
testing site configuration: coaster/teraport-gt2-gt2-pbs.xml
Running test 061-cattwo at Thu Apr 23 08:02:35 CDT 2009
RunID: 20090423-0802-2ra8nd2a
Progress:
Execution failed:
Caused by:
Cannot create directory /gpfs1
*Caused by:
refused creating directory (error code 1) [Nested exception message:
Custom message: Unexpected reply: 500-Command failed :
globus_gridftp_server_file.c:globus_l_gf\
s_file_mkdir:554:*
500-System error in mkdir: Permission denied
500-A system call failed: Permission denied
500 End.]
SWIFT RETURN CODE NON-ZERO - test 061-cattwo
SITE FAIL! Exit code 1 for site definition coaster/teraport-gt2-gt2-pbs.xml
testing site configuration: coaster/tgncsa-hg-coaster-pbs-gram2.xml
Running test 061-cattwo at Thu Apr 23 08:02:41 CDT 2009
RunID: 20090423-0802-h404ec20
Progress:
Progress:  Failed:1
Execution failed:
        Could not initialize shared directory on tgncsa-hg
Caused by:
Caused by:
        S*erver refused performing the request. Custom message: Bad
password. (error code 1) [Nested exception message:  Custom message:
Unexpected reply: 530-Login incorrect. : globus_gss_assist: Gridmap
lookup failure: Could not map /\
DC=org/DC=doegrids/OU=People/CN=Zhao Zhang 385894*
530-
530 End.]
testing site configuration: coaster/tgncsa-hg-coaster-pbs-gram4.xml
Running test 061-cattwo at Thu Apr 23 08:02:47 CDT 2009
RunID: 20090423-0802-6quf1lnb
Progress:
Progress:  Failed:1
Execution failed:
Caused by:
Caused by:
        *Server refused performing the request. Custom message: Bad
530-
530 End.]
Mihael Hategan wrote:
> Thanks.
> I think the most valuable tests are those for which there is a working
> environment (i.e. valid proxy, valid allocation, etc.)
> Mihael
> On Tue, 2009-04-21 at 13:54 -0500, Allan Espinosa wrote:
>> I ran the same testt that was was conducted w/ Zhao (his certificates
>> does not yet have any specific vo membership) and have the following
>> result:
>> Caused by:
>> 	Server refused performing the request. Custom message: Bad password.
>> (error code 1) [Nested exception message:  Custom message: Unexpected
>> reply: 530-Login incorrect. : globus_gss_assist: Gridmap lookup
>> failure: Could not map /DC=org/DC=doegrids/OU=People/CN=Allan M.
>> Espinosa 374652
>> 530-
>> 530 End.]
>> These sites failed: coaster/fletch-coaster-gram2-gram2-condor.xml
>> coaster/fletch-coaster-gram2-gram2-fork.xml
>> These sites worked: coaster/coaster-local.xml coaster/renci-engage-coaster.xml
>> cause of errors:  1.  fletch has an expired host certificate
>> 2.  i don't have teragrid allocation on tgncsa (my roaming account
>> expired). also i have a different certificate for using teragrid
>> resources.
>> attached in this email is the full log file.
>> -Allan
>> On Tue, Apr 21, 2009 at 12:55 PM, Zhao Zhang <zhaozhang at uchicago.edu> wrote:
>>> [zzhang at communicado coaster]$ grid-cert-info
>>> subject     : DC=org,DC=doegrids,OU=People,CN=Zhao Zhang 385894
>>> issuer      : DC=org,DC=DOEGrids,OU=Certificate Authorities,CN=DOEGrids CA 1
>>> start date  : Wed Feb 25 14:32:08 CST 2009
>>> end date    : Thu Feb 25 14:32:08 CST 2010
>>> [zzhang at communicado coaster]$ grid-proxy-init
>>> Your identity: DC=org,DC=doegrids,OU=People,CN=Zhao Zhang 385894
>>> Enter GRID pass phrase for this identity:        Creating proxy, please
>>> wait...
>>> Proxy verify OK
>>> Your proxy is valid until Wed Apr 22 00:54:47 CDT 2009
>>> zhao
>>> Ben Clifford wrote:
>>>> Please do all of what I asked.
>>>> On Tue, 21 Apr 2009, Zhao Zhang wrote:
>>>>> Yep, I found that my certificate has expired. I check the webpage about
>>>>> grid
>>>>> proxy, it says I need to request a new certificate.
>>>>> zhao
>>>>> [zzhang at communicado ~]$ grid-proxy-init
>>>>> Your identity: /DC=org/DC=doegrids/OU=People/CN=Zhao Zhang 385894
>>>>> Creating proxy ........................................... Done
>>>>> ERROR: Your certificate has expired: Thu Feb 26 12:47:51 2009
>>>>> Ben Clifford wrote:
>>>>>> zhao, on communicado please type:
>>>>>> grid-cert-info
>>>>>> and paste the results here.
>>>>>> Then type: grid-proxy-init and enter your password and paste the
>>>>>> results.
>>> _______________________________________________
>>> Swift-devel mailing list
>>> Swift-devel at ci.uchicago.edu
>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
