[Swift-devel] feature request
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue Apr 21 14:10:50 CDT 2009
Thanks.
I think the most valuable tests are those for which there is a working
environment (i.e. valid proxy, valid allocation, etc.)
Mihael
On Tue, 2009-04-21 at 13:54 -0500, Allan Espinosa wrote:
> I ran the same testt that was was conducted w/ Zhao (his certificates
> does not yet have any specific vo membership) and have the following
> result:
> icating with the GridFTP server
> Caused by:
> 	Server refused performing the request. Custom message: Bad password.
> (error code 1) [Nested exception message:  Custom message: Unexpected
> reply: 530-Login incorrect. : globus_gss_assist: Gridmap lookup
> failure: Could not map /DC=org/DC=doegrids/OU=People/CN=Allan M.
> Espinosa 374652
> 530-
> 530 End.]
> SWIFT RETURN CODE NON-ZERO - test 061-cattwo
> SITE FAIL! Exit code 1 for site definition
> coaster/tgncsa-hg-coaster-pbs-gram4.xml
> These sites failed: coaster/fletch-coaster-gram2-gram2-condor.xml
> coaster/fletch-coaster-gram2-gram2-fork.xml
> coaster/teraport-gt2-gt2-pbs.xml
> coaster/tgncsa-hg-coaster-pbs-gram2.xml
> These sites worked: coaster/coaster-local.xml coaster/renci-engage-coaster.xml
> cause of errors:  1.  fletch has an expired host certificate
> 2.  i don't have teragrid allocation on tgncsa (my roaming account
> expired). also i have a different certificate for using teragrid
> resources.
> attached in this email is the full log file.
> -Allan
> On Tue, Apr 21, 2009 at 12:55 PM, Zhao Zhang <zhaozhang at uchicago.edu> wrote:
> > [zzhang at communicado coaster]$ grid-cert-info
> > subject     : DC=org,DC=doegrids,OU=People,CN=Zhao Zhang 385894
> > issuer      : DC=org,DC=DOEGrids,OU=Certificate Authorities,CN=DOEGrids CA 1
> > start date  : Wed Feb 25 14:32:08 CST 2009
> > end date    : Thu Feb 25 14:32:08 CST 2010
> > [zzhang at communicado coaster]$ grid-proxy-init
> > Your identity: DC=org,DC=doegrids,OU=People,CN=Zhao Zhang 385894
> > Enter GRID pass phrase for this identity:        Creating proxy, please
> > wait...
> > Proxy verify OK
> > Your proxy is valid until Wed Apr 22 00:54:47 CDT 2009
> > zhao
> > Ben Clifford wrote:
> >> Please do all of what I asked.
> >> On Tue, 21 Apr 2009, Zhao Zhang wrote:
> >>> Yep, I found that my certificate has expired. I check the webpage about
> >>> grid
> >>> proxy, it says I need to request a new certificate.
> >>> zhao
> >>> [zzhang at communicado ~]$ grid-proxy-init
> >>> Your identity: /DC=org/DC=doegrids/OU=People/CN=Zhao Zhang 385894
> >>> Creating proxy ........................................... Done
> >>> ERROR: Your certificate has expired: Thu Feb 26 12:47:51 2009
> >>> Ben Clifford wrote:
> >>>> zhao, on communicado please type:
> >>>> grid-cert-info
> >>>> and paste the results here.
> >>>> Then type: grid-proxy-init and enter your password and paste the
> >>>> results.
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
