[Swift-devel] feature request
    Allan Espinosa
    aespinosa at cs.uchicago.edu
    Tue Apr 21 13:54:18 CDT 2009
I ran the same testt that was was conducted w/ Zhao (his certificates
does not yet have any specific vo membership) and have the following
result:
icating with the GridFTP server
Caused by:
	Server refused performing the request. Custom message: Bad password.
(error code 1) [Nested exception message:  Custom message: Unexpected
reply: 530-Login incorrect. : globus_gss_assist: Gridmap lookup
failure: Could not map /DC=org/DC=doegrids/OU=People/CN=Allan M.
Espinosa 374652
530-
530 End.]
SWIFT RETURN CODE NON-ZERO - test 061-cattwo
SITE FAIL! Exit code 1 for site definition
coaster/tgncsa-hg-coaster-pbs-gram4.xml
These sites failed: coaster/fletch-coaster-gram2-gram2-condor.xml
coaster/fletch-coaster-gram2-gram2-fork.xml
coaster/teraport-gt2-gt2-pbs.xml
coaster/tgncsa-hg-coaster-pbs-gram2.xml
These sites worked: coaster/coaster-local.xml coaster/renci-engage-coaster.xml
cause of errors:  1.  fletch has an expired host certificate
2.  i don't have teragrid allocation on tgncsa (my roaming account
expired). also i have a different certificate for using teragrid
resources.
attached in this email is the full log file.
-Allan
On Tue, Apr 21, 2009 at 12:55 PM, Zhao Zhang <zhaozhang at uchicago.edu> wrote:
> [zzhang at communicado coaster]$ grid-cert-info
> subject     : DC=org,DC=doegrids,OU=People,CN=Zhao Zhang 385894
> issuer      : DC=org,DC=DOEGrids,OU=Certificate Authorities,CN=DOEGrids CA 1
> start date  : Wed Feb 25 14:32:08 CST 2009
> end date    : Thu Feb 25 14:32:08 CST 2010
> [zzhang at communicado coaster]$ grid-proxy-init
> Your identity: DC=org,DC=doegrids,OU=People,CN=Zhao Zhang 385894
> Enter GRID pass phrase for this identity:        Creating proxy, please
> wait...
> Proxy verify OK
> Your proxy is valid until Wed Apr 22 00:54:47 CDT 2009
> zhao
> Ben Clifford wrote:
>> Please do all of what I asked.
>> On Tue, 21 Apr 2009, Zhao Zhang wrote:
>>> Yep, I found that my certificate has expired. I check the webpage about
>>> grid
>>> proxy, it says I need to request a new certificate.
>>> zhao
>>> [zzhang at communicado ~]$ grid-proxy-init
>>> Your identity: /DC=org/DC=doegrids/OU=People/CN=Zhao Zhang 385894
>>> Creating proxy ........................................... Done
>>> ERROR: Your certificate has expired: Thu Feb 26 12:47:51 2009
>>> Ben Clifford wrote:
>>>> zhao, on communicado please type:
>>>> grid-cert-info
>>>> and paste the results here.
>>>> Then type: grid-proxy-init and enter your password and paste the
>>>> results.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Allan M. Espinosa <http://allan.88-mph.net/blog>
PhD student, Computer Science
University of Chicago <http://people.cs.uchicago.edu/~aespinosa>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20090421/9ad1f920/attachment.obj>
