[Swift-devel] How to do coasters on bgp?
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Wed Apr 15 23:21:33 CDT 2009
Yes, the combination of the things you mentioned should allow you to run
on the BG/P with policies that restrict you to only a few jobs in the
queue, where each job will generally contain a large portion of the
allocation in terms of number of processors.
Ioan
Mihael Hategan wrote:
> On Wed, 2009-04-15 at 20:08 -0500, Ioan Raicu wrote:
>> I believe the BG/P is one of those machines, where static resource
>> provisioning is necessary. From the discussion we had on static vs.
>> dynamic provisioning a week or so back, I think that might be a big
>> hurdle (besides the other typical hurdles, such as network connectivity,
>> language support, and nuances specific to the BG/P). Before moving to
>> the BG/P, I'd argue for implementing static provisioning,
> I see there's still some confusion about "static provisioning". Perhaps
> we should abandon the term. Instead we could use:
> 1. pre-defined window, in which we say when the system should try to
> allocate nodes, in what amount, and for how long.
> 2. moving window, in which the system decides when to allocate nodes and
> for how long, subject to certain constraints (such as 64 nodes per job,
> 8 cores per node).
> 3. mixed mode, in which pre-defined windows could be used if available,
> and supplemented by moving windows if necessary.
Ioan Raicu, Ph.D.
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
http://dev.globus.org/wiki/Incubator/Falkon
http://dsl-wiki.cs.uchicago.edu/index.php/Main_Page
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20090415/4813e40d/attachment.html>
