[Swift-devel] feature request
    Michael Wilde
    wilde at mcs.anl.gov
    Wed Apr 15 17:46:17 CDT 2009
Zhao, based on Ben's suggestion and our earlier discussion, can you
locate and try the Swift test suite, and then look in detail at, and
try, the per-site suite.
Im looking for an assessment of what it takes to create a branch of the
suite to test coasters in th same manner that the sites are tested.
And what it takes to run that on a regular basis to find problems in
sites and Swift *before* our users find them.
In parallel, as we discussed, please check out the latest OOPS, and
follow the README under oops/swift to do an initial sanity test. Then
test the 3-site Ranger-Abe-Queenbee config, then expand to
Mercury-SDSC-ANL. All under coasters.
We'll need to map out more clearly where this is heading, but I want you
to get familiar with both OOPS and coasters, and report all problems
clearly back to the swift-devel list.
As Ben says, in a way that someone else can reproduce the problem.
Thanks.
- Mike
On 4/15/09 2:42 PM, Ben Clifford wrote:
> On Wed, 15 Apr 2009, Michael Wilde wrote:
>> I'd like to ask Zhao to do some of this testing, with OOPS on Ranger and other
>> TG and OSG sites, as prep for getting the tools in broader use in the OOPS
>> group.
> There is a per-site test suite already in place, though not run
> particularly often.
> I think any per-site testing should be based around that (for example, new
> site definitions contributed to the tests/sites/ svn directory and tests
> driven by the scripts there and any new tests also contributed there).
> I don't see coaster per-site testing to be hugely different than any other
> per-site testing (other than less of it has been done, I think)
