[Swift-devel] readData2
Ben Clifford benc at hawaga.org.uk
Wed Oct 15 05:38:47 CDT 2008
I wrote a test for this, committed in r2301.
I got a bit stuck with an issue that I thought wasn't a problem any more,
but apparently still is.
In the test, I initially said something like:
matrix m = readData2(..)
int s = m[1] + m[2];
outfile = echo(s);
which hangs.
Changing the s line to:
int s;
s=m[1]+m[2];
removes the hang - in the former case, the expression gets evaluated in
the sequential bit where variables are defined; in the latter, the s
variable is defined without a value and the expression evaluation happens
in parallel bit where data dependencies work right.
A solution in this case would be to make int s=<expr> compile to the same
definition + parallel code, rather than having that sequential.
However, I think that wil break other pieces of code - I think, for
example, mapper parameters which rely on variables having their values
defined 'before' (where 'before' is an implementation specific, rather
than SwiftScript specific temporal ordering)
Language-wise, the appropriate behaviour is to be properly dataset
dependent for all use of values in SwiftScript, I think - that's been
discussed before, and is not trivial to do. But the above is one more
quantum of motivation.
