[Swift-devel] readData2
Mihael Hategan
hategan at mcs.anl.gov
Tue Oct 14 13:41:37 CDT 2008
Due to the inflexibility of readData (made obvious by something Tibi was
trying to do), I added readData2 in r2299. It reads things from files
which have a syntax similar to the one used by the ext mapper.
Example:
type vector {
int columns[];
type matrix {
vector rows[];
matrix m;
m = readData2("readData2.in");
where readData2.in could contain:
rows[0].columns[0] = 0
rows[0].columns[1] = 2
rows[0].columns[2] = 4
rows[1].columns[0] = 1
rows[1].columns[1] = 3
rows[1].columns[2] = 5
So syntax is basically:
comments lines start with "#" and are ignored; empty lines are ignored;
<path> \hs* '=' \hs* <value>
where \hs is any horizontal whitespace.
