[Swift-devel] could swift use return code from falkon as a success notification?
Mihael Hategan
hategan at mcs.anl.gov
Thu Oct 2 17:03:31 CDT 2008
On Thu, 2008-10-02 at 16:52 -0500, Zhao Zhang wrote:
> Hi, Mihael
> I update my swift, and applied the patch. Things are working well for
> the sanity test in tests/misc/run.
> But failed when I run it with falkon on BGP.
> The log is at
> http://www.ci.uchicago.edu/~zzhang/sleep-20081002-1635-21n9ho6b.log
> <http://www.ci.uchicago.edu/%7Ezzhang/sleep-20081002-1635-21n9ho6b.log>
> The error is like this:
> Failed to transfer wrapper log from
> sleep-20081002-1635-21n9ho6b/info/9/d/bgp0
We need to fix that. That's not the actual error. The error is
2008-10-02 16:36:38,212-0500 DEBUG vdl:execute2 APPLICATION_EXCEPTION
jobid=sleep-od9m7a0j - Application exception: No status file was found.
Check the shared filesystem on bgp0
So it doesn't look like the patch made it through. Where did you apply
it?
You should apply it in the source tree and then you'll have to
re-compile swift.
