[Swift-devel] could swift use return code from falkon as a success notification?
Zhao Zhang
zhaozhang at uchicago.edu
Thu Oct 2 17:06:28 CDT 2008
I applied it in /home/falkon/cog
and run swift -sites.file ./sites.xml -tc.file ./tc.data sleep.swift in
/home/falkon/cog/module/vdsk
zhao
Mihael Hategan wrote:
> On Thu, 2008-10-02 at 16:52 -0500, Zhao Zhang wrote:
>> Hi, Mihael
>> I update my swift, and applied the patch. Things are working well for
>> the sanity test in tests/misc/run.
>> But failed when I run it with falkon on BGP.
>> The log is at
>> http://www.ci.uchicago.edu/~zzhang/sleep-20081002-1635-21n9ho6b.log
>> <http://www.ci.uchicago.edu/%7Ezzhang/sleep-20081002-1635-21n9ho6b.log>
>> The error is like this:
>> Failed to transfer wrapper log from
>> sleep-20081002-1635-21n9ho6b/info/9/d/bgp0
> We need to fix that. That's not the actual error. The error is
> 2008-10-02 16:36:38,212-0500 DEBUG vdl:execute2 APPLICATION_EXCEPTION
> jobid=sleep-od9m7a0j - Application exception: No status file was found.
> Check the shared filesystem on bgp0
> So it doesn't look like the patch made it through. Where did you apply
> it?
> You should apply it in the source tree and then you'll have to
> re-compile swift.
