[Swift-devel] could swift use return code from falkon as a success notification?
Zhao Zhang
zhaozhang at uchicago.edu
Thu Oct 2 16:52:38 CDT 2008
Hi, Mihael
I update my swift, and applied the patch. Things are working well for
the sanity test in tests/misc/run.
But failed when I run it with falkon on BGP.
The log is at
http://www.ci.uchicago.edu/~zzhang/sleep-20081002-1635-21n9ho6b.log
<http://www.ci.uchicago.edu/%7Ezzhang/sleep-20081002-1635-21n9ho6b.log>
The error is like this:
Failed to transfer wrapper log from
sleep-20081002-1635-21n9ho6b/info/9/d/bgp0
sleep-20081002-1635-21n9ho6b/info/c/c/bgp0
sleep-20081002-1635-21n9ho6b/info/8/e/bgp0
sleep-20081002-1635-21n9ho6b/info/m/i/bgp0
sleep-20081002-1635-21n9ho6b/info/q/e/bgp0
sleep-20081002-1635-21n9ho6b/info/0/e/bgp0
sleep-20081002-1635-21n9ho6b/info/5/e/bgp0
sleep-20081002-1635-21n9ho6b/info/5/i/bgp0
sleep-20081002-1635-21n9ho6b/info/2/j/bgp0
sleep-20081002-1635-21n9ho6b/info/u/i/bgp0
sleep-20081002-1635-21n9ho6b/info/1/j/bgp0
sleep-20081002-1635-21n9ho6b/info/9/e/bgp0
zhao
Mihael Hategan wrote:
> That's pretty old. The current revision is 2249.
> Alternatively you could remove the jobid argument to execute.
> On Thu, 2008-10-02 at 15:28 -0500, Zhao Zhang wrote:
>> zzhang at login6.surveyor:/home/falkon/cog/modules/vdsk/tests/misc> svn info
>> Path: .
>> URL: https://svn.ci.uchicago.edu/svn/vdl2/trunk/tests/misc
>> Repository Root: https://svn.ci.uchicago.edu/svn/vdl2
>> Repository UUID: e2bb083e-7f23-0410-b3a8-8253ac9ef6d8
>> Revision: 2169
>> Node Kind: directory
>> Schedule: normal
>> Last Changed Author: benc
>> Last Changed Rev: 2153
>> Last Changed Date: 2008-07-28 01:57:52 -0500 (Mon, 28 Jul 2008)
>> so that is 2169
>>> 2008-10-02 15:12:14,275-0500 DEBUG vdl:execute2 APPLICATION_EXCEPTION
>>> jobid=touch-zdy94a0j - Application exception: vdl:execute @ vdl-int.k,
>>> line: 395 does not support a 'jobid' argument.
>>> There's something wrong with the version of swift that you have. What is
>>> it?
>>> On Thu, 2008-10-02 at 15:15 -0500, Zhao Zhang wrote:
>>>> I rerun it, and the log is at
>>>> http://www.ci.uchicago.edu/~zzhang/130-fmri-20081002-1511-s2ezc795.log
>>>> <http://www.ci.uchicago.edu/%7Ezzhang/130-fmri-20081002-1511-s2ezc795.log>
>>>> zhao
>>>>> It would be useful if you could post the logs.
>>>>> On Thu, 2008-10-02 at 14:37 -0500, Zhao Zhang wrote:
>>>>>> After applying the patch, I rebuild falkon, and run the tests. It failed.
>>>>>> zzhang at login6.surveyor:/home/falkon/cog/modules/vdsk/tests/misc> ./run
>>>>>> Removing files from previous runs
>>>>>> Running test 130-fmri
>>>>>> Swift svn swift-r2169 (Swift modified locally) cog-r2125
>>>>>> RunID: 20081002-1429-v0e0f3a3
>>>>>> Progress:
>>>>>> touch started
>>>>>> touch started
>>>>>> touch started
>>>>>> touch started
>>>>>> Sorted: [localhost:0.000(1.000):0/1 overload: 0]
>>>>>> Sorted: [localhost:0.000(1.000):1/1 overload: 0]
>>>>>> 130-fmri-20081002-1429-v0e0f3a3/info/4/localhost
>>>>>> 130-fmri-20081002-1429-v0e0f3a3/info/3/localhost
>>>>>> Sorted: [localhost:-2.500(0.257):0/1 overload: 0]
>>>>>> 130-fmri-20081002-1429-v0e0f3a3/info/7/localhost
>>>>>> Sorted: [localhost:-4.200(0.129):0/1 overload: 0]
>>>>>> Progress: Stage in:1 Failed but can retry:3
>>>>>> 130-fmri-20081002-1429-v0e0f3a3/info/9/localhost
>>>>>> Sorted: [localhost:-5.900(0.079):0/1 overload: 0]
>>>>>> 130-fmri-20081002-1429-v0e0f3a3/info/b/localhost
>>>>>> SWIFT RETURN CODE NON-ZERO
>>>>>> test clusters ended with return value 1
>>>>>> zhao
>>>>>> Ben Clifford wrote:
>>>>>>> ok, try the same compiled code with the localhost provider running those
>>>>>>> tests. If those pass, then there may be something not working as necessary
>>>>>>> in provider-deef or falkon (the step in Mihaels instructions about getting
>>>>>>> falkon+provider-deef to return process exit codes). If not, then there is
>>>>>>> some other problem.
>>>>>>> On Wed, 1 Oct 2008, Zhao Zhang wrote:
>>>>>>>> Thanks, Ben.
>>>>>>>> First I tested the tests/misc/run, and it is ok.
>>>>>>>> Then I applied the patch, then swift failed:
>>>>>>>> Failed to transfer wrapper log from sleep-20081001-1558-in93l5j4/info/n/s/bgp0
>>>>>>>> Failed to transfer wrapper log from sleep-20081001-1558-in93l5j4/info/t/s/bgp0
>>>>>>>> Failed to transfer wrapper log from sleep-20081001-1558-in93l5j4/info/1/t/bgp0
>>>>>>>> Failed to transfer wrapper log from sleep-20081001-1558-in93l5j4/info/0/t/bgp0
>>>>>>>> sleep failed
>>>>>>>> sleep failed
>>>>>>>> sleep failed
>>>>>>>> Exception in sleep:
>>>>>>>> Arguments: [30]
>>>>>>>> Host: bgp0
>>>>>>>> Directory: sleep-20081001-1558-in93l5j4/jobs/g/s/sleep-gsski80j
>>>>>>>> stderr.txt:
>>>>>>>> stdout.txt:
>>>>>>>> zhao
>>>>>>>> Ben Clifford wrote:
>>>>>>>>> I was playing with this last week so have a patch in my stack:
>>>>>>>>> cd cog/
>>>>>>>>> wget http://www.ci.uchicago.edu/~benc/return-codes-1
>>>>>>>>> patch -p1 < ./return-codes-1
>>>>>>>>> This changes Swift behaviour but does not do anything to provider-deef,
>>>>>>>>> which might or might not work correctly at the moment.
>>>>>>>>> Running the tests in tests/misc/ by running ./run in that directory will
>>>>>>>>> help you test whether its working still or not - check they pass before you
>>>>>>>>> apply the patch, and then check afterwards too.
