[Swift-devel] could swift use return code from falkon as	a	success notification?
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Oct  2 15:24:10 CDT 2008
2008-10-02 15:12:14,275-0500 DEBUG vdl:execute2 APPLICATION_EXCEPTION
jobid=touch-zdy94a0j - Application exception: vdl:execute @ vdl-int.k,
line: 395 does not support a 'jobid' argument.
There's something wrong with the version of swift that you have. What is
it?
On Thu, 2008-10-02 at 15:15 -0500, Zhao Zhang wrote:
> I rerun it, and the log is at
> http://www.ci.uchicago.edu/~zzhang/130-fmri-20081002-1511-s2ezc795.log
> <http://www.ci.uchicago.edu/%7Ezzhang/130-fmri-20081002-1511-s2ezc795.log>
> zhao
> Mihael Hategan wrote:
> > It would be useful if you could post the logs.
> > On Thu, 2008-10-02 at 14:37 -0500, Zhao Zhang wrote:
> >> After applying the patch, I rebuild falkon, and run the tests. It failed.
> >> zzhang at login6.surveyor:/home/falkon/cog/modules/vdsk/tests/misc> ./run
> >> Removing files from previous runs
> >> Running test 130-fmri
> >> Swift svn swift-r2169 (Swift modified locally) cog-r2125
> >> RunID: 20081002-1429-v0e0f3a3
> >> Progress:
> >> touch started
> >> touch started
> >> touch started
> >> touch started
> >> Sorted: [localhost:0.000(1.000):0/1 overload: 0]
> >> Sorted: [localhost:0.000(1.000):1/1 overload: 0]
> >> Failed to transfer wrapper log from
> >> 130-fmri-20081002-1429-v0e0f3a3/info/4/localhost
> >> 130-fmri-20081002-1429-v0e0f3a3/info/3/localhost
> >> Sorted: [localhost:-2.500(0.257):0/1 overload: 0]
> >> 130-fmri-20081002-1429-v0e0f3a3/info/7/localhost
> >> Sorted: [localhost:-4.200(0.129):0/1 overload: 0]
> >> Progress:  Stage in:1 Failed but can retry:3
> >> 130-fmri-20081002-1429-v0e0f3a3/info/9/localhost
> >> Sorted: [localhost:-5.900(0.079):0/1 overload: 0]
> >> 130-fmri-20081002-1429-v0e0f3a3/info/b/localhost
> >> SWIFT RETURN CODE NON-ZERO
> >> test clusters ended with return value 1
> >> zhao
> >> Ben Clifford wrote:
> >>> ok, try the same compiled code with the localhost provider running those
> >>> tests. If those pass, then there may be something not working as necessary
> >>> in provider-deef or falkon (the step in Mihaels instructions about getting
> >>> falkon+provider-deef to return process exit codes). If not, then there is
> >>> some other problem.
> >>> On Wed, 1 Oct 2008, Zhao Zhang wrote:
> >>>> Thanks, Ben.
> >>>> First I tested the tests/misc/run, and it is ok.
> >>>> Then I applied the patch, then swift failed:
> >>>> Failed to transfer wrapper log from sleep-20081001-1558-in93l5j4/info/n/s/bgp0
> >>>> Failed to transfer wrapper log from sleep-20081001-1558-in93l5j4/info/t/s/bgp0
> >>>> Failed to transfer wrapper log from sleep-20081001-1558-in93l5j4/info/1/t/bgp0
> >>>> Failed to transfer wrapper log from sleep-20081001-1558-in93l5j4/info/0/t/bgp0
> >>>> sleep failed
> >>>> sleep failed
> >>>> sleep failed
> >>>> Exception in sleep:
> >>>> Arguments: [30]
> >>>> Host: bgp0
> >>>> Directory: sleep-20081001-1558-in93l5j4/jobs/g/s/sleep-gsski80j
> >>>> stderr.txt:
> >>>> stdout.txt:
> >>>> zhao
> >>>> Ben Clifford wrote:
> >>>>> I was playing with this last week so have a patch in my stack:
> >>>>> cd cog/
> >>>>> wget http://www.ci.uchicago.edu/~benc/return-codes-1
> >>>>> patch -p1 < ./return-codes-1
> >>>>> This changes Swift behaviour but does not do anything to provider-deef,
> >>>>> which might or might not work correctly at the moment.
> >>>>> Running the tests in tests/misc/ by running ./run in that directory will
> >>>>> help you test whether its working still or not - check they pass before you
> >>>>> apply the patch, and then check afterwards too.
