[Swift-devel] could swift use return code from falkon as a success notification?
Zhao Zhang
zhaozhang at uchicago.edu
Thu Oct 2 15:28:51 CDT 2008
zzhang at login6.surveyor:/home/falkon/cog/modules/vdsk/tests/misc> svn info
Path: .
URL: https://svn.ci.uchicago.edu/svn/vdl2/trunk/tests/misc
Repository Root: https://svn.ci.uchicago.edu/svn/vdl2
Repository UUID: e2bb083e-7f23-0410-b3a8-8253ac9ef6d8
Revision: 2169
Node Kind: directory
Schedule: normal
Last Changed Author: benc
Last Changed Rev: 2153
Last Changed Date: 2008-07-28 01:57:52 -0500 (Mon, 28 Jul 2008)
so that is 2169
Mihael Hategan wrote:
> 2008-10-02 15:12:14,275-0500 DEBUG vdl:execute2 APPLICATION_EXCEPTION
> jobid=touch-zdy94a0j - Application exception: vdl:execute @ vdl-int.k,
> line: 395 does not support a 'jobid' argument.
> There's something wrong with the version of swift that you have. What is
> it?
> On Thu, 2008-10-02 at 15:15 -0500, Zhao Zhang wrote:
>> I rerun it, and the log is at
>> http://www.ci.uchicago.edu/~zzhang/130-fmri-20081002-1511-s2ezc795.log
>> <http://www.ci.uchicago.edu/%7Ezzhang/130-fmri-20081002-1511-s2ezc795.log>
>> zhao
>>> It would be useful if you could post the logs.
>>> On Thu, 2008-10-02 at 14:37 -0500, Zhao Zhang wrote:
>>>> After applying the patch, I rebuild falkon, and run the tests. It failed.
>>>> zzhang at login6.surveyor:/home/falkon/cog/modules/vdsk/tests/misc> ./run
>>>> Removing files from previous runs
>>>> Running test 130-fmri
>>>> Swift svn swift-r2169 (Swift modified locally) cog-r2125
>>>> RunID: 20081002-1429-v0e0f3a3
>>>> Progress:
>>>> touch started
>>>> touch started
>>>> touch started
>>>> touch started
>>>> Sorted: [localhost:0.000(1.000):0/1 overload: 0]
>>>> Sorted: [localhost:0.000(1.000):1/1 overload: 0]
>>>> Failed to transfer wrapper log from
>>>> 130-fmri-20081002-1429-v0e0f3a3/info/4/localhost
>>>> 130-fmri-20081002-1429-v0e0f3a3/info/3/localhost
>>>> Sorted: [localhost:-2.500(0.257):0/1 overload: 0]
>>>> 130-fmri-20081002-1429-v0e0f3a3/info/7/localhost
>>>> Sorted: [localhost:-4.200(0.129):0/1 overload: 0]
>>>> Progress: Stage in:1 Failed but can retry:3
>>>> 130-fmri-20081002-1429-v0e0f3a3/info/9/localhost
>>>> Sorted: [localhost:-5.900(0.079):0/1 overload: 0]
>>>> 130-fmri-20081002-1429-v0e0f3a3/info/b/localhost
>>>> SWIFT RETURN CODE NON-ZERO
>>>> test clusters ended with return value 1
>>>> zhao
>>>> Ben Clifford wrote:
>>>>> ok, try the same compiled code with the localhost provider running those
>>>>> tests. If those pass, then there may be something not working as necessary
>>>>> in provider-deef or falkon (the step in Mihaels instructions about getting
>>>>> falkon+provider-deef to return process exit codes). If not, then there is
>>>>> some other problem.
>>>>> On Wed, 1 Oct 2008, Zhao Zhang wrote:
>>>>>> Thanks, Ben.
>>>>>> First I tested the tests/misc/run, and it is ok.
>>>>>> Then I applied the patch, then swift failed:
>>>>>> Failed to transfer wrapper log from sleep-20081001-1558-in93l5j4/info/n/s/bgp0
>>>>>> Failed to transfer wrapper log from sleep-20081001-1558-in93l5j4/info/t/s/bgp0
>>>>>> Failed to transfer wrapper log from sleep-20081001-1558-in93l5j4/info/1/t/bgp0
>>>>>> Failed to transfer wrapper log from sleep-20081001-1558-in93l5j4/info/0/t/bgp0
>>>>>> sleep failed
>>>>>> sleep failed
>>>>>> sleep failed
>>>>>> Exception in sleep:
>>>>>> Arguments: [30]
>>>>>> Host: bgp0
>>>>>> Directory: sleep-20081001-1558-in93l5j4/jobs/g/s/sleep-gsski80j
>>>>>> stderr.txt:
>>>>>> stdout.txt:
>>>>>> zhao
>>>>>> Ben Clifford wrote:
>>>>>>> I was playing with this last week so have a patch in my stack:
>>>>>>> cd cog/
>>>>>>> wget http://www.ci.uchicago.edu/~benc/return-codes-1
>>>>>>> patch -p1 < ./return-codes-1
>>>>>>> This changes Swift behaviour but does not do anything to provider-deef,
>>>>>>> which might or might not work correctly at the moment.
>>>>>>> Running the tests in tests/misc/ by running ./run in that directory will
>>>>>>> help you test whether its working still or not - check they pass before you
>>>>>>> apply the patch, and then check afterwards too.
