[Swift-devel] could swift use return code from falkon as a success notification?
Zhao Zhang
zhaozhang at uchicago.edu
Thu Oct 2 15:15:09 CDT 2008
I rerun it, and the log is at
http://www.ci.uchicago.edu/~zzhang/130-fmri-20081002-1511-s2ezc795.log
<http://www.ci.uchicago.edu/%7Ezzhang/130-fmri-20081002-1511-s2ezc795.log>
zhao
Mihael Hategan wrote:
> It would be useful if you could post the logs.
> On Thu, 2008-10-02 at 14:37 -0500, Zhao Zhang wrote:
>> After applying the patch, I rebuild falkon, and run the tests. It failed.
>> zzhang at login6.surveyor:/home/falkon/cog/modules/vdsk/tests/misc> ./run
>> Removing files from previous runs
>> Running test 130-fmri
>> Swift svn swift-r2169 (Swift modified locally) cog-r2125
>> RunID: 20081002-1429-v0e0f3a3
>> Progress:
>> touch started
>> touch started
>> touch started
>> touch started
>> Sorted: [localhost:0.000(1.000):0/1 overload: 0]
>> Sorted: [localhost:0.000(1.000):1/1 overload: 0]
>> Failed to transfer wrapper log from
>> 130-fmri-20081002-1429-v0e0f3a3/info/4/localhost
>> 130-fmri-20081002-1429-v0e0f3a3/info/3/localhost
>> Sorted: [localhost:-2.500(0.257):0/1 overload: 0]
>> 130-fmri-20081002-1429-v0e0f3a3/info/7/localhost
>> Sorted: [localhost:-4.200(0.129):0/1 overload: 0]
>> Progress: Stage in:1 Failed but can retry:3
>> 130-fmri-20081002-1429-v0e0f3a3/info/9/localhost
>> Sorted: [localhost:-5.900(0.079):0/1 overload: 0]
>> 130-fmri-20081002-1429-v0e0f3a3/info/b/localhost
>> SWIFT RETURN CODE NON-ZERO
>> test clusters ended with return value 1
>> zhao
>> Ben Clifford wrote:
>>> ok, try the same compiled code with the localhost provider running those
>>> tests. If those pass, then there may be something not working as necessary
>>> in provider-deef or falkon (the step in Mihaels instructions about getting
>>> falkon+provider-deef to return process exit codes). If not, then there is
>>> some other problem.
>>> On Wed, 1 Oct 2008, Zhao Zhang wrote:
>>>> Thanks, Ben.
>>>> First I tested the tests/misc/run, and it is ok.
>>>> Then I applied the patch, then swift failed:
>>>> Failed to transfer wrapper log from sleep-20081001-1558-in93l5j4/info/n/s/bgp0
>>>> Failed to transfer wrapper log from sleep-20081001-1558-in93l5j4/info/t/s/bgp0
>>>> Failed to transfer wrapper log from sleep-20081001-1558-in93l5j4/info/1/t/bgp0
>>>> Failed to transfer wrapper log from sleep-20081001-1558-in93l5j4/info/0/t/bgp0
>>>> sleep failed
>>>> sleep failed
>>>> sleep failed
>>>> Exception in sleep:
>>>> Arguments: [30]
>>>> Host: bgp0
>>>> Directory: sleep-20081001-1558-in93l5j4/jobs/g/s/sleep-gsski80j
>>>> stderr.txt:
>>>> stdout.txt:
>>>> zhao
>>>> Ben Clifford wrote:
>>>>> I was playing with this last week so have a patch in my stack:
>>>>> cd cog/
>>>>> wget http://www.ci.uchicago.edu/~benc/return-codes-1
>>>>> patch -p1 < ./return-codes-1
>>>>> This changes Swift behaviour but does not do anything to provider-deef,
>>>>> which might or might not work correctly at the moment.
>>>>> Running the tests in tests/misc/ by running ./run in that directory will
>>>>> help you test whether its working still or not - check they pass before you
>>>>> apply the patch, and then check afterwards too.
