[Swift-devel] could swift use return code from falkon as a	success notification?
    Ben Clifford
    benc at hawaga.org.uk
    Wed Oct  1 17:43:28 CDT 2008
ok, try the same compiled code with the localhost provider running those
tests. If those pass, then there may be something not working as necessary
in provider-deef or falkon (the step in Mihaels instructions about getting
falkon+provider-deef to return process exit codes). If not, then there is
some other problem.
On Wed, 1 Oct 2008, Zhao Zhang wrote:
> Thanks, Ben.
> First I tested the tests/misc/run, and it is ok.
> Then I applied the patch, then swift failed:
> Failed to transfer wrapper log from sleep-20081001-1558-in93l5j4/info/n/s/bgp0
> Failed to transfer wrapper log from sleep-20081001-1558-in93l5j4/info/t/s/bgp0
> Failed to transfer wrapper log from sleep-20081001-1558-in93l5j4/info/1/t/bgp0
> Failed to transfer wrapper log from sleep-20081001-1558-in93l5j4/info/0/t/bgp0
> sleep failed
> sleep failed
> sleep failed
> Exception in sleep:
> Arguments: [30]
> Host: bgp0
> Directory: sleep-20081001-1558-in93l5j4/jobs/g/s/sleep-gsski80j
> stderr.txt:
> stdout.txt:
> zhao
> Ben Clifford wrote:
> > I was playing with this last week so have a patch in my stack:
> > cd cog/
> > wget http://www.ci.uchicago.edu/~benc/return-codes-1
> > patch -p1 < ./return-codes-1
> > This changes Swift behaviour but does not do anything to provider-deef,
> > which might or might not work correctly at the moment.
> > Running the tests in tests/misc/ by running ./run in that directory will
> > help you test whether its working still or not - check they pass before you
> > apply the patch, and then check afterwards too.
