[Swift-devel] could swift use return code from falkon as a success	notification?
    Zhao Zhang
    zhaozhang at uchicago.edu
    Wed Oct  1 16:52:54 CDT 2008
Thanks, Ben.
First I tested the tests/misc/run, and it is ok.
Then I applied the patch, then swift failed:
Failed to transfer wrapper log from
sleep-20081001-1558-in93l5j4/info/n/s/bgp0
sleep-20081001-1558-in93l5j4/info/t/s/bgp0
sleep-20081001-1558-in93l5j4/info/1/t/bgp0
sleep-20081001-1558-in93l5j4/info/0/t/bgp0
sleep failed
sleep failed
sleep failed
Exception in sleep:
Arguments: [30]
Host: bgp0
Directory: sleep-20081001-1558-in93l5j4/jobs/g/s/sleep-gsski80j
stderr.txt:
stdout.txt:
zhao
Ben Clifford wrote:
> I was playing with this last week so have a patch in my stack:
> cd cog/
> wget http://www.ci.uchicago.edu/~benc/return-codes-1
> patch -p1 < ./return-codes-1
> This changes Swift behaviour but does not do anything to provider-deef,
> which might or might not work correctly at the moment.
> Running the tests in tests/misc/ by running ./run in that directory will
> help you test whether its working still or not - check they pass before
> you apply the patch, and then check afterwards too.
