[Swift-devel] testing replication
    lixi at uchicago.edu
    Thu May 22 13:06:25 CDT 2008
I see. How silly I am!
Thanks so much. :)
Xi
---- Original message ----
>Date: Thu, 22 May 2008 13:02:20 -0500
>From: Mihael Hategan <hategan at mcs.anl.gov>
>Subject: Re: [Swift-devel] testing replication
>To: lixi at uchicago.edu
>Cc: Ben Clifford <benc at hawaga.org.uk>, swift-
devel at ci.uchicago.edu
>On Thu, 2008-05-22 at 12:50 -0500, lixi at uchicago.edu wrote:
>> I knew these values. My intention is that we might could
>> turn these factors into variables which could be changed
for
>> each run. Is that possible or has that been already
>> implemented?
>As I mentioned before, you can edit libexec/scheduler.xml
>You'll see something like this:
><scheduler type="vds-adaptive" shareID="vdl2:scheduler:
{sites}">
>  <property name="transformationCatalogFile"
value="{tcfile}"/>
></scheduler>
>You can set your own properties there. For example:
><property name="jobSubmissionTaskLoadFactor" value="-1"/>
>> Thanks,
>> Xi
