[Swift-devel] restart variable scoping.
Ben Clifford benc at hawaga.org.uk
Thu May 22 08:09:16 CDT 2008
wrt to the on-going activity around bug NNN about restarts...
if it is desirable to label restarts based on variable name, rather than
by the mapped filename, then:
the naive approach of storing the variable name as restart identifier:
 * works for global variables
 * does not work for non-global variables, because the same variable name
   can be used in different scopes, and the same code block can be invoked
   multiple times (in procedures and in for loops, for example)
Some kind of scope identifier on the front might help here. In:
  (file t) p() {
     file q=foo();
     t=qux(q);
  a=p();    // l1
  b=p();    // l2
the variable 'q' is used twice, once in the call at l1, and once in the
call at l2.
So one might use 'l1' and 'l2', the locations in the source file, as scope
identifiers, giving restart identifiers of l1.q and l2.q.
In a foreach loop, such as:
foreach a,i in array {  // l3
   out[i] = p(array); // l4
we might then scope the various instances of q as:
   l3-iteration1.l4.q
   l3-iteration2.l4.q
   l3-iteration3.l4.q
with scope labelling being hierarchical.
The scope identifier is:
  the containing scope identifier
  whatever is needed to identify the new child scope within the containing
  scope
So: entering a foreach loop block appends the iteration identifier to the
current scope; making a function call appends the function call source
location (or equivalent) to the current scope.
This is mostly based around me thinking about a SwiftScript level of
thinking, rather than a Karajan level of thinking - it may be that this
is not easy to do at the karajan level (indeed, it may be that this
doesn't work at all anyway). But it seemed worth sending anyway.
