[Swift-devel] proper way to run swift on resource using condor?
Mike Kubal
mikekubal at yahoo.com
Wed May 21 11:20:31 CDT 2008
Thanks all.
My docking application is running now on Purdue using
jobmanager-condor without any need for the perl script
calling condor_submit. I had tried jobmanager-condor
previously and when it failed I assumed I needed to
incorporate the condor_submit.
--- Ben Clifford <benc at hawaga.org.uk> wrote:
> > You should be able to use GRAM2 for this, using
> the details on here:
> > However, it appears to not work at the moment
> TG people at Purdue have fixed this now.
> Have a look at tests/sites/tgpurdue-condor-gram2.xml
> (in swift svn
> >=r1995)
> That is a sites file that I use (as of a few minutes
> ago) for running my
> semi-automated site tests; it passes all tests apart
> from ones with spaces
> in filenames (which is a problem with gram+condor in
> general).
> You will need to change the project ID (or remove
> that entirely if you
> have a default teragrid project) and change the
> workdirectory to something
> of your own.
> Run examples/vdsk/first.swift to check it works. You
> should see from that
> that it works basically the same as submitting to
> PBS on other TeraGrid
> sites, with no need to do condor specific things at
> the far side.
