[Swift-devel] proper way to run swift on resource using condor?
    Stuart Martin
    smartin at mcs.anl.gov
    Wed May 21 09:48:02 CDT 2008
Looking at the kit registrations for remote compute kits, purdue has
WS GRAM (version 4.0.1 very old) registered.  But maybe it is not
running.  Seems the kit registration should only say a version.  Then
the actual contact information (host:port/service path) should be only
be listed when the container is up running.  I think JP has made the
latest remote compute kit available that includes WS GRAM from 4.0.7 +
an rft patch.  So we should ask Purdue to install that.  Does that
make sense JP?
http://info.teragrid.org:8080/webmds/webmds?info=tgislocal&xsl=kitsregistration
Name	Type	Version	Endpoint
prews-gram-condor	prews-gram	4.0.1	tg-condor.purdue.teragrid.org:2119/
jobmanager-condor
globus-mds	globus-mds4	4.0.1	https://tg-condor.purdue.teragrid.org:8443/wsrf/services/DefaultIndexService
ws-delegation	ws-delegation	4.0.1	https://tg-condor.purdue.teragrid.org:8443/wsrf/services/DelegationService
ws-gram/Condor	ws-gram	4.0.1	https://tg-condor.purdue.teragrid.org:8443/wsrf/services/ManagedJobFactoryService
globus-mds-auth	globus-mds4	4.0.1	https://tg-condor.purdue.teragrid.org:8448/wsrf/services/DefaultIndexService
ws-gram/Fork	ws-gram	4.0.1	https://tg-condor.purdue.teragrid.org:8443/wsrf/services/ManagedJobFactoryService
prews-gram-fork	prews-gram	4.0.1	tg-condor.purdue.teragrid.org:2119/
jobmanager-fork
On May 21, 2008, at May 21, 5:54 AM, Ben Clifford wrote:
> You should be able to use GRAM2 for this, using the details on here:
> http://www.teragrid.org/userinfo/hardware/resources.php?type=compute&select=single&id=16
> or here:
> http://www.teragrid.org/userinfo/jobs/gram.php
> However, it appears to not work at the moment (either with Swift or
> with a
> simple commandline submission globus-job-run
> tg-condor.purdue.teragrid.org/jobmanager-fork /bin/hostname)
> I'll poke the teragrid helpdesk and CC you.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
