[Swift-devel] proper way to run swift on resource using condor?
    Ben Clifford
    benc at hawaga.org.uk
    Wed May 21 09:37:36 CDT 2008
> You should be able to use GRAM2 for this, using the details on here:
> However, it appears to not work at the moment
TG people at Purdue have fixed this now.
Have a look at tests/sites/tgpurdue-condor-gram2.xml (in swift svn
>=r1995)
That is a sites file that I use (as of a few minutes ago) for running my
semi-automated site tests; it passes all tests apart from ones with spaces
in filenames (which is a problem with gram+condor in general).
You will need to change the project ID (or remove that entirely if you
have a default teragrid project) and change the workdirectory to something
of your own.
Run examples/vdsk/first.swift to check it works. You should see from that
that it works basically the same as submitting to PBS on other TeraGrid
sites, with no need to do condor specific things at the far side.
