[Swift-devel] proper way to run swift on resource using condor?
Ben Clifford
benc at hawaga.org.uk
Wed May 21 05:54:10 CDT 2008
You should be able to use GRAM2 for this, using the details on here:
http://www.teragrid.org/userinfo/hardware/resources.php?type=compute&select=single&id=16
or here:
http://www.teragrid.org/userinfo/jobs/gram.php
However, it appears to not work at the moment (either with Swift or with a
simple commandline submission globus-job-run
tg-condor.purdue.teragrid.org/jobmanager-fork /bin/hostname)
I'll poke the teragrid helpdesk and CC you.
