[Swift-devel] gram4 detecting own host identity
    Ian Foster
    foster at mcs.anl.gov
    Sun May 18 15:01:09 CDT 2008
Ben:
I'd recommend talking to your colleagues in the GRAM team--Stu Martin
and Martin Feller in particular.
Ian.
On May 18, 2008, at 12:45 PM, Ben Clifford wrote:
> (I just sent this by accident to the secret SWFT list - it was
> intended
> for this list, swift-devel)
> A couple (or maybe three) times in the past few days I've seen the
> GRAM4
> submission be extremely bad at detecting its own identity to use in
> WS-Notification subscriptions - it seems to end up using 'localhost'
> rather than the global-scope hostname...
> Here is one from andrew.bsd.uchicago.edu, for example (it also
> happens on
> wiggum and on my laptop):
> <ns1:ConsumerReference><wsa:Address>https://localhost:50000/
> wsrf/services/NotificationConsumerService</wsa:Address>
> These machines, as far as any sane unix person would think, are
> correctly
> identifying themselves with the hostname command, have proper
> forward and
> reverse DNS set up, and the like; pretty much everything else can
> figure
> out the local identity correctly; so the workaround 'set
> GLOBUS_HOSTNAME
> to your hostname' seems unnecessarily complicated in these cases.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
