[Swift-devel] gram4 detecting own host identity
    Martin Feller
    feller at mcs.anl.gov
    Sun May 18 16:47:01 CDT 2008
Ben:
I assume you mean the NotificationConsumer in the context of a subscription for job status
notifications, which is created on the client-side and used in a job submission to Gram4 to
create a subscription resource, right?
How is the NotificationConsumer with the defective address created on the client-side:
using Gram4's GramJob, or by other means?
I think in any event it goes down to Java WS Core, since it's there where the address
of the NotificationConsumer is generated.
(NotificationConsumerManager.createNotificationConsumer() ->
 ClientNotificationConsumerManager.getURL() -> ServiceContainer.getURL()
 and finally the host seems to come from ServiceHost.getHost())
Gram4 does not set addresses in endpoints of NotificationConsumers itself.
Maybe Rachana can shed some light on this, or correct me if I'm wrong.
Does setting GLOBUS_HOSTNAME solve the issue? I know, you mentioned that you think
this complicates the matter, but for debugging ...
Is this 4.0 or upcoming 4.2 specific, or do you experience that problem for both?
Martin
----- Original Message -----
To: "Ben Clifford" <benc at hawaga.org.uk>
Cc: swift-devel at ci.uchicago.edu, "Stuart Martin" <smartin at mcs.anl.gov>, "Martin Feller" <feller at mcs.anl.gov>
Sent: Sunday, May 18, 2008 3:01:09 PM GMT -06:00 US/Canada Central
Subject: Re: [Swift-devel] gram4 detecting own host identity
Ben:
I'd recommend talking to your colleagues in the GRAM team--Stu Martin
and Martin Feller in particular.
Ian.
On May 18, 2008, at 12:45 PM, Ben Clifford wrote:
> (I just sent this by accident to the secret SWFT list - it was
> intended
> for this list, swift-devel)
> A couple (or maybe three) times in the past few days I've seen the
> GRAM4
> submission be extremely bad at detecting its own identity to use in
> WS-Notification subscriptions - it seems to end up using 'localhost'
> rather than the global-scope hostname...
> Here is one from andrew.bsd.uchicago.edu, for example (it also
> happens on
> wiggum and on my laptop):
> <ns1:ConsumerReference><wsa:Address>https://localhost:50000/
> wsrf/services/NotificationConsumerService</wsa:Address>
> These machines, as far as any sane unix person would think, are
> correctly
> identifying themselves with the hostname command, have proper
> forward and
> reverse DNS set up, and the like; pretty much everything else can
> figure
> out the local identity correctly; so the workaround 'set
> GLOBUS_HOSTNAME
> to your hostname' seems unnecessarily complicated in these cases.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
