[Swift-devel] Re: swift-falkon problem
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Mon Mar 24 08:46:21 CDT 2008
Michael Wilde wrote:
> Ioan: I do see that we're loosing some workers, so some investigation
> is needed on the Falkon side.
I see that some workers remain in a pending state for about a minute,
after which the same amount of workers that are in pending state
register as new workers, and the number of available workers gets back
up to what we had to begin with.  I think I removed a few months back
the mechanism that went through periodically and cleaned up the pending
workers... which is leaving them stuck in a pending state in the logs.
I'll try to add that back in.
Now, for the real problem why these workers are ending up in a pending
state, and never going to a running state, we need to do more debugging.
Ioan
> - Mike
> On 3/23/08 7:12 PM, Ben Clifford wrote:
>> On Fri, 21 Mar 2008, Mihael Hategan wrote:
>>> On Fri, 2008-03-21 at 07:12 -0500, Michael Wilde wrote:
>>>> My latest test on runs of 25, 100, and 1000 jobs seem to indicate that
>>>> with a sync command at the end of the application script, all job
>>>> status
>>>> and data is returned ok every time.
>>> Why not put it in the wrapper script at the end?
>> Mike, the attached patch will do that, and will also add logging
>> information so that we can see how long syncs are taking compared to
>> other stages in worker node execution.
>> cd cog/modules/vdsk
>> patch -p1 < sync-in-wrapper
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Ioan Raicu
Ph.D. Candidate
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
http://dev.globus.org/wiki/Incubator/Falkon
http://dsl-wiki.cs.uchicago.edu/index.php/Main_Page
