[Swift-devel] Re: swift-falkon problem
Ben Clifford benc at hawaga.org.uk
Mon Mar 24 04:46:20 CDT 2008
you can get plots for your 1000 job run here:
http://www.ci.uchicago.edu/~benc/report-amps1-20080323-1935-su38n0k5/
you're hitting the file transfer and file operation limits (that are 20 in
your config) once jobs start staging out.
There's a wierd looking plateu in graph 'number of execute2 tasks at
once:' around 170s .. 200s where no jobs complete for some time.
Getting the falkon logs and/or the wrapper (.d) logs would be interesting
there.
these were generated on my laptop with:
make \
 LOG=/Users/benc/work/everylog/amps1-20080323-1935-su38n0k5.log clean \
 webpage.weights webpage.kara webpage
using the SVN log-procesisng code.
