[Swift-devel] Re: swift-falkon problem
Ioan Raicu
iraicu at cs.uchicago.edu
Mon Mar 17 07:43:22 CDT 2008
Ben Clifford wrote:
> So from the Swift log you paste, this line:
> 2008-03-16 16:43:44,213-0600 DEBUG TaskImpl Task(type=JOB_SUBMISSION,
> identity=urn:0-1-1-1205707420808) setting status to Active
> identity=urn:0-1-1-1205707420808) setting status to Failed
> suggests that provider-deef is reporting a failure up to the Swift
> runtime. There may be some more logs that you can turn on at the
> provider-deef or falkon layer, but I don't know what the likely ones would
> be.
iraicu at viper:~/java/svn/cog/modules/provider-deef/etc> cat
log4j.properties.module
log4j.logger.org.apache.axis.utils.JavaUtils=ERROR
log4j.logger.org.globus.cog.abstraction.impl.execution.deef=DEBUG
I have this log4j property, do you have this enabled? This should
enable more debug output from the Falkon provider.
> From a process point-of-view, I'm concerned about this:
>> - the deef-provider code that I get with a swift checkout seems to have
>> out
>> of date falkon stubs (I get a runtime error on a missing xml element)
>> - if I grab a FalkonStubs jar from Zhao's bgp swift tree and use it in a
>> newly compiled swift tree, should that work? It seems to get further.
> If provider-deef needs updating, those updates should be made in SVN; if
> it doesn't need updating, then you have some other problem. Ioan and Zhao,
> if you had to update something to make it work, please commit that change.
I know we should update SVN, we just haven't gotten around to it. I
just updated the stubs in the Swift SVN (R1727). Mike, give it a try
again from SVN.
Ioan
Ioan Raicu
Ph.D. Candidate
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web: http://www.cs.uchicago.edu/~iraicu
http://dev.globus.org/wiki/Incubator/Falkon
http://dsl-wiki.cs.uchicago.edu/index.php/Main_Page
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20080317/6f83ab44/attachment.html>
