[Swift-devel] Re: swift-falkon problem
    Michael Wilde
    wilde at mcs.anl.gov
    Mon Mar 17 08:34:28 CDT 2008
I did a clean checkout to get the latest rev directly on the bblogin
machine (previously I copied the code).
Strange: this time provider-deef didnt show up in the modules directory.
  I *thought* last time it did, unless I'm imagining things.
Did something just change w.r.t provider-deef, or is my memory faulty?
- Mike
On 3/17/08 7:43 AM, Ioan Raicu wrote:
> Ben Clifford wrote:
>> So from the Swift log you paste, this line:
>> 2008-03-16 16:43:44,213-0600 DEBUG TaskImpl Task(type=JOB_SUBMISSION,
>> identity=urn:0-1-1-1205707420808) setting status to Active
>> identity=urn:0-1-1-1205707420808) setting status to Failed
>> suggests that provider-deef is reporting a failure up to the Swift
>> runtime. There may be some more logs that you can turn on at the
>> provider-deef or falkon layer, but I don't know what the likely ones would
>> be.
> iraicu at viper:~/java/svn/cog/modules/provider-deef/etc> cat
> log4j.properties.module
> log4j.logger.org.apache.axis.utils.JavaUtils=ERROR
> log4j.logger.org.globus.cog.abstraction.impl.execution.deef=DEBUG
> I have this log4j property, do you have this enabled?  This should
> enable more debug output from the Falkon provider.
>> >From a process point-of-view, I'm concerned about this:
>>> - the deef-provider code that I get with a swift checkout seems to have
>>> out
>>> of date falkon stubs (I get a runtime error on a missing xml element)
>>> - if I grab a FalkonStubs jar from Zhao's bgp swift tree and use it in a
>>> newly compiled swift tree, should that work? It seems to get further.
>> If provider-deef needs updating, those updates should be made in SVN; if
>> it doesn't need updating, then you have some other problem. Ioan and Zhao,
>> if you had to update something to make it work, please commit that change.
> I know we should update SVN, we just haven't gotten around to it.  I
> just updated the stubs in the Swift SVN (R1727).  Mike, give it a try
> again from SVN.
> Ioan
> Ioan Raicu
> Ph.D. Candidate
> Distributed Systems Laboratory
> Computer Science Department
> University of Chicago
> 1100 E. 58th Street, Ryerson Hall
> Chicago, IL 60637
> Email: iraicu at cs.uchicago.edu
> Web:   http://www.cs.uchicago.edu/~iraicu
> http://dev.globus.org/wiki/Incubator/Falkon
> http://dsl-wiki.cs.uchicago.edu/index.php/Main_Page
