[Swift-devel] Re: swift-falkon problem
Ben Clifford benc at hawaga.org.uk
Mon Mar 17 06:05:15 CDT 2008
So from the Swift log you paste, this line:
2008-03-16 16:43:44,213-0600 DEBUG TaskImpl Task(type=JOB_SUBMISSION,
identity=urn:0-1-1-1205707420808) setting status to Active
identity=urn:0-1-1-1205707420808) setting status to Failed
suggests that provider-deef is reporting a failure up to the Swift
runtime. There may be some more logs that you can turn on at the
provider-deef or falkon layer, but I don't know what the likely ones would
be.
>From a process point-of-view, I'm concerned about this:
> - the deef-provider code that I get with a swift checkout seems to have
> out
> of date falkon stubs (I get a runtime error on a missing xml element)
> - if I grab a FalkonStubs jar from Zhao's bgp swift tree and use it in a
> newly compiled swift tree, should that work? It seems to get further.
If provider-deef needs updating, those updates should be made in SVN; if
it doesn't need updating, then you have some other problem. Ioan and Zhao,
if you had to update something to make it work, please commit that change.
