[Swift-devel] swift-falkon problem
    Michael Wilde
    wilde at mcs.anl.gov
    Sun Mar 16 19:48:23 CDT 2008
Ioan,
Im stuck at:
RunID: 20080316-1643-g4n8t252
Progress:
runam3 started
error: Notification(int timeout): socket = new ServerSocket(recvPort);
Address already in use
Waiting for notification for 0 ms
Received notification with 1 messages
Failed to transfer wrapper log from amps1-20080316-1643-g4n8t252/info/0/sico
runam3 failed
Execution failed:
         Exception in runam3:
Arguments: [0000, 0.1899, 0.1858]
Host: sico
Does this look familiar?
What Im confused about is:
- the deef-provider code that I get with a swift checkout seems to have
out of date falkon stubs (I get a runtime error on a missing xml element)
- if I grab a FalkonStubs jar from Zhao's bgp swift tree and use it in a
newly compiled swift tree, should that work? It seems to get further.
It *seems* like swift is reaching Falkon - I can see something in a
falkon logfile that looks like swift-generated job ids) but then I'm
getting the errors above.
The log file doesnt contain any details, just whats below.
I'll double-check all my steps and package up the full log file, but
wanted to get this out to you before I spend too much more time
debugging, hoping someone recognizes the problem.
I note that I havent yet found the strings above, like "Waiting for
notification" in the swift source tree.
Mike
2008-03-16 16:43:42,807-0600 INFO  vdl:createdirset END
jobid=runam3-0cu5avpi - Done initializing directory structure
2008-03-16 16:43:42,809-0600 INFO  vdl:dostagein START
jobid=runam3-0cu5avpi - Staging in files
2008-03-16 16:43:42,810-0600 INFO  vdl:dostagein END
jobid=runam3-0cu5avpi - Staging in finished
2008-03-16 16:43:42,812-0600 DEBUG vdl:execute2 JOB_START
jobid=runam3-0cu5avpi tr=runam3 arguments=[0000, 0.1899, 0.1858]
tmpdir=amps1-20080316-1643-g4n8t252/jobs/0/runam3-0cu5avpi host=sico
2008-03-16 16:43:42,829-0600 DEBUG WeightedHostScoreScheduler
multiplyScore(sico:0.000(1.000):1/1000002, -0.2)
2008-03-16 16:43:42,829-0600 DEBUG WeightedHostScoreScheduler Old score:
0.000, new score: -0.200
2008-03-16 16:43:43,693-0600 DEBUG TaskImpl Task(type=JOB_SUBMISSION,
identity=urn:0-1-1-1205707420808) setting status to Submitting
identity=urn:0-1-1-1205707420808) setting status to Submitted
2008-03-16 16:43:43,693-0600 DEBUG WeightedHostScoreScheduler Submission
time for Task(type=JOB_SUBMISSION, identity=urn:0-1-1-1205707420808):
0ms. Score delta: 0.002564102564102564
2008-03-16 16:43:43,694-0600 DEBUG WeightedHostScoreScheduler
multiplyScore(sico:-0.200(0.889):1/889402, 0.002564102564102564)
2008-03-16 16:43:43,694-0600 DEBUG WeightedHostScoreScheduler Old score:
-0.200, new score: -0.197
2008-03-16 16:43:43,694-0600 INFO  JobSubmissionTaskHandler Job submitted
2008-03-16 16:43:44,213-0600 DEBUG TaskImpl Task(type=JOB_SUBMISSION,
identity=urn:0-1-1-1205707420808) setting status to Active
identity=urn:0-1-1-1205707420808) setting status to Failed
2008-03-16 16:43:44,218-0600 DEBUG vdl:execute2 APPLICATION_EXCEPTION
jobid=runam3-0cu5avpi - Application exception: Task failed
         task:execute @ vdl-int.k, line: 386
         sys:sequential @ vdl-int.k, line: 378
         sys:try @ vdl-int.k, line: 377
         task:allocatehost @ vdl-int.k, line: 356
         vdl:execute2 @ execute-default.k, line: 23
         sys:restartonerror @ execute-default.k, line: 21
         sys:sequential @ execute-default.k, line: 19
         sys:try @ execute-default.k, line: 18
         sys:if @ execute-default.k, line: 17
         sys:then @ execute-default.k, line: 16
         sys:if @ execute-default.k, line: 15
         vdl:execute @ amps1.kml, line: 52
         runam3 @ amps1.kml, line: 92
         sys:sequential @ amps1.kml, line: 91
         sys:parallelfor @ amps1.kml, line: 73
         sys:sequential @ amps1.kml, line: 72
         doall @ amps1.kml, line: 142
         sys:sequential @ amps1.kml, line: 141
         sys:parallel @ amps1.kml, line: 131
         vdl:mainp @ amps1.kml, line: 130
         mainp @ vdl.k, line: 150
         vdl:mains @ amps1.kml, line: 128
         rlog:restartlog @ amps1.kml, line: 126
         kernel:project @ amps1.kml, line: 2
