[Swift-devel] Re: misc swift errors
    skenny at uchicago.edu
    Fri Mar 14 16:42:30 CDT 2008
so, ben is suggesting that the use of relative paths within
the swift script may be the problem here.
can you rerun giving the mapper the full path?
string
inputName=@strcat("/disks/gpfs/fmri/cnari/swift/lhROI7_4p2filter_input/sub.",subject,".block",file,".txt");
---- Original message ----
>Date: Fri, 14 Mar 2008 14:53:10 -0500
>From: "Uri Hasson" <uhasson at gmail.com>
>Subject: Re: misc swift errors
>To: skenny at uchicago.edu
>Hi Sarah,
>I'm using the following:
>A swift properties file:
>/disks/gpfs/fmri/cnari/swift/projects/uhasson/peakfit_project/all_runs/run_0314_lhREG7_f4p2/swift.properties
>and config files in
>/disks/gpfs/fmri/cnari/swift/projects/uhasson/peakfit_project/swift.conf
>On Fri, Mar 14, 2008 at 2:51 PM,  <skenny at uchicago.edu> wrote:
>> which config files (tc.data and sites.xml) are you using for
>>  this run?
>>  >Date: Fri, 14 Mar 2008 14:30:35 -0500
>>  >Subject: misc swift errors
>>  >To: "Sarah Kenny" <skenny at uchicago.edu>, "Mihael Hategan"
>>  <hategan at mcs.anl.gov>
>>  >Hey SWIFT gurus.. I'm running swift heavy duty and
>>  encountering some
>>  >errors I can't track.
>>  >1) In a log file of a run that's still ongoing there are
>>  errors on
>>  >"status files not" found:
>/disks/gpfs/fmri/cnari/swift/projects/uhasson/peakfit_project/all_runs/run_0314_lhREG8_f4p2/ccf-perm-wf-20080314-1308-g61h5kic.log
>>  >But the job seems to be continuing...
>>  >2) another run simply crashed with errors. Log at:
>/disks/gpfs/fmri/cnari/swift/projects/uhasson/peakfit_project/all_runs/run_0314_lhREG7_f4p2/ccf-perm-wf-20080314-1006-ix8mnzfb.log
>>  >It sais it can't link to a file that exists..
>>  >Any ideas -- much appreciated.
>>  >Uri
