[Swift-devel] workflow run with the newest Swift
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri Jun 27 13:44:49 CDT 2008
On Fri, 2008-06-27 at 17:35 +0000, Ben Clifford wrote:
> On Fri, 27 Jun 2008, lixi at uchicago.edu wrote:
> > I'm launching a Swift run at 10:49. The first job of this
> > workflow was submitted to a site. However, it is still
> > waiting for running on the remote site until now according
> > to log file. I enabled the replication option, so I think
> > that it should produce copy job and submit it to other sites.
> > The log file is on CI:
> > /home/lixi/newswift/test/newversion/workflowtest-20080627-
> > 1049-4p7s1tne.log
> > I don't terminate this run yet.
> > Please help to check it, thanks.
> In the present implementation, replication will never happen until one job
> has completed. If your first job hits a slow site, then you will be in
> trouble.
> It might be useful to have other controls on replication - for example, an
> initial time to use when a mean time is not known, that might be set to
> half an hour or something like that.
Right. I agree.
> I think you should probably restart that run and see how it works.
