[Swift-devel] workflow run with the newest Swift
    Ben Clifford
    benc at hawaga.org.uk
    Fri Jun 27 12:35:14 CDT 2008
On Fri, 27 Jun 2008, lixi at uchicago.edu wrote:
> I'm launching a Swift run at 10:49. The first job of this
> workflow was submitted to a site. However, it is still
> waiting for running on the remote site until now according
> to log file. I enabled the replication option, so I think
> that it should produce copy job and submit it to other sites.
> The log file is on CI:
> /home/lixi/newswift/test/newversion/workflowtest-20080627-
> 1049-4p7s1tne.log
> I don't terminate this run yet.
> Please help to check it, thanks.
In the present implementation, replication will never happen until one job
has completed. If your first job hits a slow site, then you will be in
trouble.
It might be useful to have other controls on replication - for example, an
initial time to use when a mean time is not known, that might be set to
half an hour or something like that.
I think you should probably restart that run and see how it works.
