[Swift-devel] coaster + fletch-condor command line truncation
    Mihael Hategan
    hategan at mcs.anl.gov
    Sun Jun 15 18:56:02 CDT 2008
On Sun, 2008-06-15 at 23:48 +0000, Ben Clifford wrote:
> If I submit to fletch using coasters and gt2:fork, my tests run OK.
> If I tell coasters to use gt2:condor to submit workers, then I get
> problems with commandline truncation - 130-fmri has a job in the middle
> with a bunch of input files.
> r2073 adds the two sites files that demonstrate this:
> cd tests/sites/
> ./run-site coaster/fletch-coaster-gram2-gram2-fork.xml
> works for me and
> ./run-site coaster/fletch-coaster-gram2-gram2-condor.xml
> does not work for me.
> The jobs that fail get run on gwynn.bsd.uchicago.edu most of the time. So
> I tried running coasters locally on gwynn itself
> (tests/sites/coaster-local.xml) and that works ok.
> I have not dug into this deeply; however at first glance it seems somewhat
> puzzling.
> Changing the mechanism by which coaster workers are submitted should not
> change the command-line handling of jobs submitted through coasters; at
> least not from my general understanding of coaster architecture.
> Maybe there is something funny happening with different shell or perl
> versions or something like that.
May it be that the condor/gram version installed there is different and
fixes some of the quoting problems resulting in twice quoted things?
