[Swift-devel] coaster + fletch-condor command line truncation
Ben Clifford
benc at hawaga.org.uk
Sun Jun 15 19:05:15 CDT 2008
On Sun, 15 Jun 2008, Mihael Hategan wrote:
> May it be that the condor/gram version installed there is different and
> fixes some of the quoting problems resulting in twice quoted things?
The job command lines shouldn't be going anywhere near condor in this
setup though, I think.
I added a commandline log to the wrapper. It looks truncated rather than
funnily quoted.
_____________________________________________________________________________
command line
touch-mg5926ui -jobdir m -e /bin/touch -out stdout.txt -err stderr.txt -i
-d _co
ncurrent/aligned-028fa5e1-234d-45bf-bc3f-d4c3296c1802--array//elt-3.-field|_conc
urrent/aligned-028fa5e1-234d-45bf-bc3f-d4c3296c1802--array//elt-2.-field|_concur
rent/aligned-028fa5e1-234d-45bf-bc3f-d4c3296c1802--array//elt-4.-field|_concurre
nt/aligned-028fa5e1-234d-45bf-bc3f-d4c3296c1802--array//elt-1.-field|_concurrent
/brainatlas-c5b15ce2-fe89-49a7-864c-43ada7185721--field -if
_concurrent/aligned-
028fa5e1-234d-45bf-bc3f-d4c3296c1802--array//elt-3.-field/h|_concurrent/aligned-
028fa5e1-234d-45bf-bc3f-d4c3296c1802--array//elt-3.-field/v|_concurrent/aligned-
028fa5e1-234d-45bf-bc3f-d4c3296c1802--array//elt-2.-field/h|_concurrent/aligned-
028fa5e1-234d-45bf-bc3f-d4c3296c1802--array//elt-2.-field/v|_concurrent/aligned-
028fa5e1-234d-45bf-bc3f-d4c3296c1802--array//elt-4.-field/h|_concurrent/aligned-
028fa5e1-234d-45bf-bc3f-d4c3296c1802--array//elt-4.-field/v|_concurrent/aligned-
028fa5e1-234d-45bf-bc3f-d4c3296c1802--array//elt-1.-field/h|_concurrent/aligned-
028fa5e1-234d-45bf-bc3f-d4c3296c1802--array//elt-1.-field/v -of
_concurrent/brai
natlas-c5b15ce2-fe89-49a7-864c-43ada7185721--field/h|_concurrent/brainatlas-c5b1
5ce2-fe89-49a7-864c-43ada7185721--field/v -k
