[Swift-devel] coastersPerNode not recognized by GT2 GRAM
Michael Wilde wilde at mcs.anl.gov
Wed Jul 30 09:42:57 CDT 2008
I need to set this aside for now, but would appreciate any help in
debugging it.
My sites.xml file is:
<config>
<pool handle="abe" >
   <execution provider="coaster" url="grid-abe.ncsa.teragrid.org"
jobManager="gt2:gt2:pbs" />
   <gridftp url="gsiftp://gridftp-abe.ncsa.teragrid.org"/>
   <workdirectory>/u/ac/wilde/swiftwork</workdirectory>
   <profile namespace="globus" key="coastersPerNode">8</profile>
</pool>
</config>
The logs are on CI net at /home/wilde/coast/run17.
I dont see how this works. Is the code picking up the parameter from the
  globus RSL and then passing it to bootstrap.sh to in turn pass it to
the coaster server? It needs to be stripped off the globus profile
before the GT2 job that launches bootstrap.sh is run, right?  Else
Globus will complain that its not valid RSL?
I see the one test case for this in tests/sites/coaster is for
localhost. Was it tested on gt2:gt2:pbs?
- Mike
On 7/30/08 6:42 AM, Michael Wilde wrote:
> When I use coastersPerNode on Abe I get an error:
> 2008-07-30 01:06:43,498-0500 DEBUG vdl:execute2 APPLICATION_EXCEPTION
> jobid=echo-9g3mu8xi - Application exception: Cannot submit job
> org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
> Cannot submit job
> at
> org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.submitSingleJob(JobSubmissionTaskHandler.java:162)
> Caused by: org.globus.gram.GramException: Parameter not supported
> Do the globus namespace options get put into RSL in GRAM2, and do these
> need to be valid Globus options?
> I assume this option is in the globus namespace because that was a
> convenient way of adding per-site options?  Or was this mean to be in
> the karajan namespace?
> I'll dig deeper, but wonder if this has been tested on TeraGrid sites.
> - Mike
> On 7/27/08 2:58 PM, Ben Clifford wrote:
>  > cog svn r2094 introduces a profile property coastersPerNode which allows
>  > you to spawn multiple coaster workers on a node. this should allow
> you to
>  > take advantage of sites which have multicore CPUs but allocate the whole
>  > node, rather than an individual core, when a job is submitted.
>  > When using coasters, add this to the site definition:
>  >     <profile namespace="globus" key="coastersPerNode">5</profile>
>  > to get eg 5 workers on each node.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
