[Swift-devel] coastersPerNode not recognized by GT2 GRAM
Michael Wilde
wilde at mcs.anl.gov
Wed Jul 30 06:42:33 CDT 2008
When I use coastersPerNode on Abe I get an error:
2008-07-30 01:06:43,498-0500 DEBUG vdl:execute2 APPLICATION_EXCEPTION
jobid=echo-9g3mu8xi - Application exception: Cannot submit job
org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
Cannot submit job
at
org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.submitSingleJob(JobSubmissionTaskHandler.java:162)
Caused by: org.globus.gram.GramException: Parameter not supported
Do the globus namespace options get put into RSL in GRAM2, and do these
need to be valid Globus options?
I assume this option is in the globus namespace because that was a
convenient way of adding per-site options? Or was this mean to be in
the karajan namespace?
I'll dig deeper, but wonder if this has been tested on TeraGrid sites.
- Mike
On 7/27/08 2:58 PM, Ben Clifford wrote:
> cog svn r2094 introduces a profile property coastersPerNode which allows
> you to spawn multiple coaster workers on a node. this should allow
you to
> take advantage of sites which have multicore CPUs but allocate the whole
> node, rather than an individual core, when a job is submitted.
> When using coasters, add this to the site definition:
> <profile namespace="globus" key="coastersPerNode">5</profile>
> to get eg 5 workers on each node.
