[Swift-devel] coastersPerNode not recognized by GT2 GRAM
Michael Wilde
wilde at mcs.anl.gov
Wed Jul 30 11:05:28 CDT 2008
Im able to work around this on abe for now by hardcoding coasterPerNode
to 8 and removing the <profile> tag from sites.xml. That works.
- Mike
On 7/30/08 9:42 AM, Michael Wilde wrote:
> I need to set this aside for now, but would appreciate any help in
> debugging it.
> My sites.xml file is:
> <config>
> <pool handle="abe" >
> <execution provider="coaster" url="grid-abe.ncsa.teragrid.org"
> jobManager="gt2:gt2:pbs" />
> <gridftp url="gsiftp://gridftp-abe.ncsa.teragrid.org"/>
> <workdirectory>/u/ac/wilde/swiftwork</workdirectory>
> <profile namespace="globus" key="coastersPerNode">8</profile>
> </pool>
> </config>
> The logs are on CI net at /home/wilde/coast/run17.
> I dont see how this works. Is the code picking up the parameter from the
> globus RSL and then passing it to bootstrap.sh to in turn pass it to
> the coaster server? It needs to be stripped off the globus profile
> before the GT2 job that launches bootstrap.sh is run, right? Else
> Globus will complain that its not valid RSL?
> I see the one test case for this in tests/sites/coaster is for
> localhost. Was it tested on gt2:gt2:pbs?
> - Mike
> On 7/30/08 6:42 AM, Michael Wilde wrote:
>> When I use coastersPerNode on Abe I get an error:
>> 2008-07-30 01:06:43,498-0500 DEBUG vdl:execute2 APPLICATION_EXCEPTION
>> jobid=echo-9g3mu8xi - Application exception: Cannot submit job
>> org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
>> Cannot submit job
>> at
>> org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.submitSingleJob(JobSubmissionTaskHandler.java:162)
>> Caused by: org.globus.gram.GramException: Parameter not supported
>> Do the globus namespace options get put into RSL in GRAM2, and do
>> these need to be valid Globus options?
>> I assume this option is in the globus namespace because that was a
>> convenient way of adding per-site options? Or was this mean to be in
>> the karajan namespace?
>> I'll dig deeper, but wonder if this has been tested on TeraGrid sites.
>> - Mike
>> On 7/27/08 2:58 PM, Ben Clifford wrote:
>> > cog svn r2094 introduces a profile property coastersPerNode which
>> allows
>> > you to spawn multiple coaster workers on a node. this should allow
>> you to
>> > take advantage of sites which have multicore CPUs but allocate the
>> whole
>> > node, rather than an individual core, when a job is submitted.
>> > When using coasters, add this to the site definition:
>> > <profile namespace="globus" key="coastersPerNode">5</profile>
>> > to get eg 5 workers on each node.
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
