[Swift-devel] Re: Is there a way to make swift send 256 tasks at a time
Ioan Raicu iraicu at cs.uchicago.edu
Wed Jul 23 09:12:56 CDT 2008
Michael Wilde wrote:
> But, I suspect you want *exactly* 256 to keep all the cores in each
> pset busy without over-committing jobs. So what I think the best you
> can do is start with the throttle at 3, and the score at 85 which will
> give you 3 * 85 + 2 = 257 jobs. If the throttle creeps up for good
> behavior, then you'll wind up with a little overcomiting, which isnt
> bad. It wont go over 302 with a throttle of 3.
Can the throttle.score.job.factor be set to a float?  Then setting it to
2.54 will give you exactly 256, assuming all tasks come back successful.
> I suspect we could try a patch that prevents the score from changing.
> Can you tell from Falkon logs as we ramp up testing of this, whether
> overcomiting is a problem? I suspect at worst it will exacerbate
> tail-effects as the workflow is winding down and some resources sit
> idle while others are overcomited.
Yes, it is the tail end of the runs that will be most affected.
> Lastly, note that the fact that the score can drop might eventually
> prove useful in handling psets that go bad in the middle of long runs.
Right!
Ioan
Ioan Raicu
Ph.D. Candidate
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
http://dev.globus.org/wiki/Incubator/Falkon
http://dsl-wiki.cs.uchicago.edu/index.php/Main_Page
