[Swift-devel] Re: Is there a way to make swift send 256 tasks at a time
Ben Clifford
benc at hawaga.org.uk
Wed Jul 23 04:42:56 CDT 2008
On Tue, 22 Jul 2008, Michael Wilde wrote:
> I suspect we could try a patch that prevents the score from changing.
You could, though settings as you described should keep the system
saturated just about right anyway; if something breaks in one pset, then
allowing swift to stop using that pset will be a feature not a bug in
terms of proper run completion... as you note yourself...
> Lastly, note that the fact that the score can drop might eventually prove
> useful in handling psets that go bad in the middle of long runs. We dont have
> enough experience yet to see how frequent that will be at 640 psets, or how
> such errors wil be manifested.
So I'd be inclined to not interfere with the code; you can use jobThrottle
and initialScore to say you want about 256 jobs and to start at full
steam, and I think that should suffice.
