[Swift-devel] Question regarding ip.address
Ioan Raicu iraicu at cs.uchicago.edu
Tue Jul 22 12:17:43 CDT 2008
Zhao,
You just need a way to pass an IP address to the deef provider... so
might as well do:
export GLOBUS_HOSTNAME=182.17.3.16
and then read the environment variable "GLOBUS_HOSTNAME" in the deef
provider and get the IP address that way.  This is assuming that the
-ip.address option in Swift doesn't work as you expected.
Ioan
Ben Clifford wrote:
> On Tue, 22 Jul 2008, Zhao Zhang wrote:
>> I have a question about the following parameter of swift.
>> 1. Is this feature enabled in current release of swift?
>> 2. If I specify it as "swift -ip.address 172.17.3.16 first.swift", is that
>> correct?
> I usually set GLOBUS_HOSTNAME in the environment rather than specifying a
> commandline parameter; that works for me regularly.
> eg:
>   $ export GLOBUS_HOSTNAME=182.17.3.16
> If you're adding in non-Swift stuff like provider-deef, I haven't tested
> how that responds to the above configuration.
Ioan Raicu
Ph.D. Candidate
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
http://dev.globus.org/wiki/Incubator/Falkon
http://dsl-wiki.cs.uchicago.edu/index.php/Main_Page
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20080722/d813cddd/attachment.html>
